ngk irridium spark plugs
Old Dec 22, 2007 | 08:53 PM
the beast14's Avatar
the beast14
Default ngk irridium spark plugs
I bought some ngk irridium spark plugs and I want to know what should I gap them at
Old Dec 22, 2007 | 09:06 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: ngk irridium spark plugs
They should be pre gapped for your application when you get them..........they are very, very hard to regap without breaking them.
Dusty
Old Dec 23, 2007 | 09:57 PM
Moparmatt440's Avatar
Moparmatt440
Yea they do come pre gapped, but it really depends on your boost level, if your higher then stock then you need to close the gap a bit, I am running about 10 psi spike to 15 on and I gapped mine to .040, factory is what .050 or something, when I left mine stock I miss fired due to higher boost lowered the gap now it runs fine. Liek Dusty said be careful they can break
Old Dec 24, 2007 | 07:35 AM
71RoadRunner's Avatar
71RoadRunner
If you do regap them or any plugs for that matter you'll want a wire gap gauge, the gradualdisc gap gauges are no good if you want a precise measurement.
Old Dec 24, 2007 | 08:05 AM
Burnnout's Avatar
Burnnout
If you bought the NGK 4306's they do not come pregapped...
Old Dec 24, 2007 | 02:22 PM
srt4ACRboy's Avatar
srt4ACRboy
I have mine gapped at .045.
Old Dec 24, 2007 | 02:52 PM
PSI Chick's Avatar
PSI Chick
irridiums and coppers are not gapped at the same levels. leave the irridiums alone, just check that they are all gapped the same. if you start getting blow out then adjust, but usually the irridiums are fine.
Old Dec 26, 2007 | 06:04 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
ORIGINAL: Burnnout
I would start at .35
Old Dec 27, 2007 | 12:22 AM
PSI Chick's Avatar
PSI Chick
again....THESE ARE NOT COPPERS. irridiums need a larger gap than coppers do. on a stock car irridiums work perfectly well at .050-.052.
Old Dec 27, 2007 | 10:16 AM
Burnnout's Avatar
Burnnout
I just saw ngk and started typing... i'll take my foot out of my mouth now.
