I think I need parts
Old Dec 23, 2007 | 08:24 PM
STILL GH3TtO's Avatar
STILL GH3TtO
Default I think I need parts
Hey guys, I have an 05 with a 50 trim and i am seeing that most of you have parts that i dont and i was wondering if i should... I am going to list everything that i have installed on the car and see if you think i need to buy some things,
Agp 50 trim kit,bb & polished housing
agp intake
750cc rc injectors
walboro fuel pump
d-tech fuel/boost
k sport kontrol coilovers
clutchmasters stage 4
flywheel
Big fmic
hks ssqv and pipe
powere rear windows
foglight mod
I think thats all, thanks
Old Dec 23, 2007 | 08:36 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: I think I need parts
motor mounts, the everfamous catch can, and if you dont already ahve one, definately you need a wideband, exhaust
btw, how are your power rear windows done, where did you opt to mount the switches?
Old Dec 23, 2007 | 11:29 PM
motorboy1's Avatar
motorboy1
lol, you have a few I'd like to have. Looks likeI need to buy some things!
I agreewithFlamingpinheadon all that, Andwould add a wider set of tires if you don't already have them.
Old Dec 24, 2007 | 04:32 AM
STILL GH3TtO
oops forgot about the mounts, agp. and i bust bought a B&B exhaust ( only 450 used(: ) and I will buy an Oil catch can but i dont know how to install it, or the wideband.... are they difficult?? And the tires I am waiting on because ithink i am a little too throttlehappy right now. but i am going to buy the Konig hot swaps, can i go 8 1/2 inch wide?? how do i post pictures... sorry i am computer illiterate
Old Dec 24, 2007 | 07:18 AM
lblackneon's Avatar
lblackneon
There are plenty of other things you can get. It just depends how much you want to spend.
Hardpipes, windage tray, pickup tube, a better pcm, STS, booger bushings, traction bars, motor mounts, etc.
You can go on SRT forums and find out how to install some gauges. I'd recommend you find a shop to do it if you don't have a clue.
Old Dec 24, 2007 | 08:10 AM
Burnnout's Avatar
Burnnout
Wideband install is 2/10 difficulty lvl I would say...... You need to get a fuel return line.
Old Dec 24, 2007 | 11:37 AM
flamingpinhead
Section Moderator
yes a return linethat thought crossed my mind the on second read of the thread
and a catch can install is easier than changing the oil... really
8 1/2" would be madd wide. you would have to be careful with the offset and your suspension, as you might end up with some rub
Old Dec 24, 2007 | 02:53 PM
PSI Chick's Avatar
PSI Chick
a windage tray and pick up tube? those are mods that you do basically when everything else is already done. there are much more important things to be getting, as has been listed above.
Old Dec 24, 2007 | 04:53 PM
STILL GH3TtO
what is a windage tray and pick up tube..... and flamingpin head my switches to my rear windows are mounted right above the e brake...
Old Dec 24, 2007 | 06:40 PM
lblackneon's Avatar
lblackneon
ORIGINAL: PSI Chick
Yeah.
Sorry; you did say something you need. The stuff I listed is just nice to have.
The DCR windage tray and pickup tube basically help oil flow.
