bigger injecters
Old Dec 25, 2007 | 01:28 PM
lblackneon's Avatar
lblackneon
Default RE: bigger injecters
ORIGINAL: PSI Chick
you cannot tune a dtech per gear. only a standalone can do that.
Actually you can tune the fuel and boost per gear with the Dtech. Since my car was dyno tuned up north, coming down to Florida changed my A/F ratios. I had my car street tuned until I can get it tuned back at the dyno again. They just adjusted my fuel in 3rd and 4th gear to be safe.
Old Dec 26, 2007 | 08:51 AM
Burnnout's Avatar
Burnnout
Hmm.... to my knowledge a DTEC will only tune at certain rpm ranges.... i've neverheard ofan option for boost or fuel levels at a specific gear....then again I don't own one.
Old Dec 26, 2007 | 11:19 AM
lblackneon's Avatar
lblackneon
Everyone is talking about 3 different Detecs. Here it is:
http://www.agpturbo.com/product.php?...cat=255&page=1
I forget what rpm increments but with my Detec Fuel controller/Boost controller, you can tune the fuel in the rpm increments in every gear. Like I said, you can also adjust the boost in every gear.
Old Dec 26, 2007 | 12:59 PM
STILL GH3TtO's Avatar
STILL GH3TtO
how do i do that?? i Also have the fuel and boost and i want to turn the boost down in first and second..... if it possible
Old Dec 26, 2007 | 01:26 PM
lblackneon's Avatar
lblackneon
Yes you can lower the boost in the first few gears. I have my boost set to 10lbs in first and 15 in second. With the Detech, all you have to do is go in the fuel and boost parameters, lower the number, and save the settings.
