bigger injecters
Old Dec 24, 2007 | 05:05 PM
the beast14's Avatar
the beast14
Default bigger injecters
Adding bigger injerters will it give me more horsepower
Old Dec 24, 2007 | 07:58 PM
faststage02005's Avatar
faststage02005
Default RE: bigger injecters
yes it will...but you need something to tune the fuel...like dtec....
Old Dec 24, 2007 | 10:12 PM
the beast14
How will I tune the d-tec
Old Dec 24, 2007 | 11:29 PM
faststage02005
you can street tune it
Old Dec 25, 2007 | 02:38 AM
STILL GH3TtO's Avatar
STILL GH3TtO
how do you street tune with the d-tec.... and can you adjust boost per gear??
Old Dec 25, 2007 | 02:43 AM
lblackneon's Avatar
lblackneon
First off, is your car stock? Adding larger injectors by itself wont do anything. The SRT-4 already runs rich from the factory. If anything, you would be better off taking fuel out. That'll benefit your performance. If your stock, there are plenty of other mods you should do first.
With a Dtech, you can adjust the boost per gear.
Old Dec 25, 2007 | 02:47 AM
lblackneon's Avatar
lblackneon
Didn't you say you have a 50 trim, 750cc injectors, etc. anyway? The only way you can tune the Dtech or do anything with the fuel is if you have a Air fuel Wideband gauge. I don't see how or even why you have a Dtech without a wideband gauge. Other than that, if you really do have 750cc injectors, there is no reason you should get larger injectors unless you need to. The only reason you would need to get larger injectors is if you get a larger turbo.
Old Dec 25, 2007 | 11:29 AM
the beast14
I have bigger fmic, agp piping and agp wastegate, nitrous intercooler sprayer, intake and downpipe
Old Dec 25, 2007 | 11:52 AM
PSI Chick's Avatar
PSI Chick
you cannot tune a dtech per gear. only a standalone can do that.
Old Dec 25, 2007 | 11:54 AM
faststage02005
if you add injectors and a dtec you can raise the boost safely to 18 to 19psi to redline....
