QUESTIONS TO BE ANSWERED
Old Dec 28, 2007 | 02:06 PM
daporkchop03's Avatar
daporkchop03
Default RE: QUESTIONS TO BE ANSWERED
ok you got a point lol i ran bone stock a 13.9 at 101.69 but like i feel the difference of when the car wants to move and doesnt. also i forgot to mention that ma turbo is making a different sound when it spools up liek a louder screamin sound that it never did before
Old Dec 28, 2007 | 04:42 PM
PSI Chick's Avatar
PSI Chick
when was the last time you changed your plugs and wires? you also should retune your wga/mbc to a 18 spike holding 15 or so.
Old Dec 28, 2007 | 09:46 PM
daporkchop03
i cahnged mine not to long ago. because i had a misfire. so i changed the plugs wires and coilpack. i took my manuel boost controller out and it seems to b alot faster. maybe that was the problem since i was boostin so high then held at low boost
Old Dec 28, 2007 | 10:14 PM
old school's Avatar
old school
When my turbo makes a louder "scream" than usual it is because it blew out the airflow sensor in the intake tube right before the throtle body. I eventually had to use a long wire tie to wrap around the tube , between the two little wires and over the top of the sensor to keep it from blowing out about once a week.
Old Dec 29, 2007 | 09:21 AM
daporkchop03
my codes are P2074-MANIFOLD PRESSURE/THROTTLE POSITION CORRELATION
- HIGH FLOW/VACUUM LEAK for me to fix that wat should i check
Old Dec 29, 2007 | 11:31 AM
PSI Chick's Avatar
PSI Chick
your car only "feels" faster with no mbc, it's actually not. you probably had it tuned wrong. set the wga to 12psi and the mbc to 15 or so.
Old Dec 29, 2007 | 11:57 AM
Burnnout's Avatar
Burnnout
It may be faster if it's not spiking to 20 and hitting fuel cut .... but ifyou setit upcorrectly likePSI just told you it will be better.
Old Dec 29, 2007 | 01:53 PM
daporkchop03
i took ma boost controller and it feels alot fater it goes to like 16 or 17 psi holding no mroe fuel cutout. but it sais p2074 vacumm leak maybe that could be the problem or why is that on.. wat effect does it do to the car and how would i fix that. for me to turn it to 12 on the wga how would i do that clockwise or counter clockwise
Old Dec 30, 2007 | 11:23 AM
faststage02005's Avatar
faststage02005
if you make the wastegate arm longer is less boost...the shorter the more boost...
