Normal Boost in 1st
Old Dec 28, 2007 | 12:17 PM
srt4ever's Avatar
srt4ever
Default Normal Boost in 1st
What should I be seeing for normal boost numbers in 1st gear?
I am stock, no mods.
I am luck at WOT if I see it hit 1 or 2 mostly just bearly at 0...is that normal?
The rest of the gears are fine.
Thanks for any help.
Old Dec 28, 2007 | 12:33 PM
faststage02005's Avatar
faststage02005
Default RE: Normal Boost in 1st
you should be at like 9psi in first gear...
Old Dec 28, 2007 | 03:19 PM
srt4ever's Avatar
srt4ever
Any ideas why I am not?
Old Dec 28, 2007 | 04:41 PM
PSI Chick's Avatar
PSI Chick
a really big boost leak probably
Old Dec 30, 2007 | 01:58 AM
71RoadRunner's Avatar
71RoadRunner
If it were a boost leak, especially a substantial one, it would suffer the loss in all gears and not just in 1st.
srt4ever,
You say the boost is fine in all the other gears, how much boost is it showing in those gears?
Old Dec 30, 2007 | 06:13 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
^yeah, depends on what 'fine' is in other gears. also, where does your boost gauge sit when you are at idle, and where does it read when the car is off?
does your car feel any slower than it used to (all gears)?
either you got a massive boostleak as psi said, or you have a busted boost gauge
Old Dec 31, 2007 | 09:11 AM
srt4ever's Avatar
srt4ever
I guess I owe you people an appoligy...I pushed the pedal to the floor in first just yesterday, to recheck what is going on(I have not done this before!!!) I watched the boost guage closely...I hit about 5-7 PSI and then I backed off, the tires were smoking and squeeling!!! Sorry, I guess everything is just fine....
Old Dec 31, 2007 | 10:59 AM
MEandmySRT's Avatar
MEandmySRT
glad things seem normal, but as mentioned it wouldn't hurt to check the obvious clamps for boost leaks. my factory clamps were 2-3 turns loose at cooler, pipes, tbody and the turbo. i've since upgraded all to t-bolt clamps and making roughly 18.5 pounds boost to redline on warm days and 15 when it's 20 degrees out. [stage 2 numbers]
Old Jan 1, 2008 | 07:19 AM
flamingpinhead
Section Moderator
havent checked up on mine in a while either, will get on that next time im under the car
Old Jan 15, 2008 | 07:35 PM
MAssSrTdriven's Avatar
MAssSrTdriven
i have about 9-12 i think in first gear weather dependant of course. like on these colder days its much lower im lucky to see higher numbers....
