fuel question
Old Jan 13, 2008 | 03:45 AM
drewthatsmenb's Avatar
drewthatsmenb
Default RE: fuel question
alright, thanks for the input guys i'll def. check out the tps and i'll read up on the afc manuel and ask some of the other srt guys around my area if i have any questions i'll post again. but once again thanks for all the info.
Old Jan 29, 2008 | 01:14 AM
drewthatsmenb
hey you guys were rite my buddy used a scanner to check out the check engine light and the tps came up on it thanks guys
Old Jan 29, 2008 | 10:55 AM
Burnnout's Avatar
Burnnout
Anytime
Old Jan 29, 2008 | 01:04 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
wow, yet another tic mark under TPS
Old Jan 29, 2008 | 04:18 PM
daporkchop03's Avatar
daporkchop03
yea i got a 02 housing 3 inch downpipe 2.5 mopar exhuast stage 2 wg, mbc cai, 20psi not holding
wat should i get for fuel was is the best thing that does not cost alot of money,
Old Jan 29, 2008 | 09:22 PM
flamingpinhead
Section Moderator
safc/dtec (see above posts),probably a return line, larger fuel rail and larger injectors, oh, and a fuel pump. youll also want a wideband to keep an eye on your a/f ratio... and a tune would be a good idea as well with the safc
