Upgrades
Old Jan 11, 2008 | 06:15 PM
dparsons06's Avatar
dparsons06
Default Upgrades
I am fairly new to this whole upgrading stuff, so far i have a Cold Air Intake and stage 1 is somewhere in the mail. What should i go with next?
Old Jan 11, 2008 | 07:01 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: Upgrades
which way you go depends on where you want to end up
Old Jan 11, 2008 | 08:52 PM
faststage02005's Avatar
faststage02005
get a catch can... and new plugs and wires if you havent got them yet....
Old Jan 11, 2008 | 10:41 PM
dparsons06's Avatar
dparsons06
i planned on getting msd ignition and new plugs and wires, if there any certain brand i should get for the wires and plugs? and also the can?
Old Jan 11, 2008 | 11:46 PM
Moparmatt440's Avatar
Moparmatt440
Stay with the stock coil, the stock and the MSD are pretty much the same and some people on this forum say that they are crap. I personally use the Magnecore 8.5mm race wires with NGK iridium plugs, plus get a wire protector, moderenperformacen sells them for a good price, it will save your #4 wire. A can is a can some use greddy, weapon r, depends on what you like. I just have a little vile looking one that was on the car when I bought it.
drewthatsmenb's Avatar
drewthatsmenb
i got ngk 1 step colder plugs and ngk 10.2mm wires and they work great but i'm sure that msd would also be good too as for next mod i would go with a cat back or a down pipe hell even both if you want free up some power and get more air flow [sm=goodidea.gif]
Old Jan 11, 2008 | 11:50 PM
drewthatsmenb
catch can, if you plan on getting new motor mounts stay away from the weapon r catch can it mounts to your stock motor mount i found out the hard way [&o]
Old Jan 12, 2008 | 02:38 AM
faststage02005
you should get a turbo back.....this will free up a couple of ponies... than a wastegate if you want to turn up the boost a bit....
Old Jan 12, 2008 | 07:41 AM
dparsons06's Avatar
dparsons06
Ok thank you guys for your help, now i just need to wait for taxes and do some over time and ill start buying stuff and let you know how it goes, anymore input is welcome
Old Jan 12, 2008 | 10:19 AM
flamingpinhead
Section Moderator
ORIGINAL: drewthatsmenb
i tried ordering that from modernperformance a couple years back and it was discontinued then. didnt think you could even find them anymore. but the NRG catch can (same dang thing as Greddy but diff name) will work best. if you have a CAI, you can just mount it off the battery tray next to the intake tubing. worked out well for me there.
but the catch can is a given first 'mod'
btw, if you find you have something more to add to your post, its better if you use the edit button and add to it instead of making a separate reply.
