i need help installing new boost guage
Old Jan 11, 2008 | 08:50 PM
faststage02005's Avatar
faststage02005
Default i need help installing new boost guage
i just baught a "glow shift" boost mechanical 30/30 guage but i dont know how to install it.... any help will be appreciated.....
Old Jan 12, 2008 | 12:02 PM
faststage02005
Default RE: i need help installing new boost guage
anybody???
Old Jan 12, 2008 | 06:52 PM
motorboy1's Avatar
motorboy1
going in stock location? u'll have to take the dash pad off to get the gauge out. I looked for a how too and didn't see one.
Old Jan 12, 2008 | 06:59 PM
motorboy1's Avatar
motorboy1
This will help with the dash. after that ull see how the gauge goes.
Lets start with taking the dash apart.
With this step you will need to take your side pillars, Dash top.
You will need to place your index and middle finger along the roof going under the top of the side pillar then gently pull towards the seats. There are two metal clips per side/pillar (the top one might break if it does this isnt a major problem the pillar will still stay in place when put back).
There are four screws that hold the Dash Top down, along with some compression clips. The screws are located one on either side of the dash. (You have to have the doors open to see) The other two are located in your defroster vent one on either side of the opening. (These two will not come all the way out of their setting)
Once you have the screws all out you will need to now gently pull up on your dash. It is going to "pop" off.
Now before you try to pull the dash out of the car you will need to unplug the boost gauge and the light for the boost gauge. These are going to be right in front of you as you are sitting in the drivers seat. The vacuum line just needs to be pulled to separate and the light wire has a clip that you need to press on to separate.
Old Jan 12, 2008 | 08:11 PM
faststage02005
thanks
