plugs and wired
Old Jan 12, 2008 | 03:57 AM
bigdrewab's Avatar
bigdrewab
Default plugs and wired
where is a good place to buy plugs and wired for drt-4
Old Jan 12, 2008 | 09:28 AM
Burnnout's Avatar
Burnnout
Default RE: plugs and wired
If you want to get wired, drink a couplered bulls..... drt-4's parts are currently on backorder.... seriouslythough...turboneonstore.com modernperformance.com.... etc etc google is your friend.
Old Jan 12, 2008 | 04:10 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
MSD makes great plug wires.....plugs are a matter of personal choice.........
Dusty
Old Jan 12, 2008 | 05:43 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
just search for threads about which plugs... there has been much discussion in the past on this.
as for the wires, dont go cheap on those! modernperformance was already suggested, i would see what the have there
Old Jan 12, 2008 | 05:46 PM
MEandmySRT's Avatar
MEandmySRT
ORIGINAL: bigdrewab
sparkplugs.com
and if you have a 2005 you may need to say it's a 2004 to get a full list of wires in the product box option.
Old Jan 12, 2008 | 06:30 PM
faststage02005's Avatar
faststage02005
i baught the bosch from autozone and they work good for the past 8 months
Old Jan 13, 2008 | 09:13 PM
Moparmatt440's Avatar
Moparmatt440
I only use NGK's iridiums plugs with Magnecore wires. Plus get a plug wire shield it will prolong the life of your new wires.
Just a question has anyone ever tried the pulstar plugs, supposely they produce a higher spark due to a a capasitor inside the plug? Thoughts????
Old Jan 13, 2008 | 10:11 PM
Burnnout's Avatar
Burnnout
You should never put a bosch plug in your car... unless it's from germany. Bosch double platinums is what Autozone pushes on every customer that walks in the door......employess get insentives for selling set amounts.
Old Jan 13, 2008 | 10:33 PM
faststage02005
no im talking bout bosch wires. i have ngk iridium plugs.....
Old Jan 14, 2008 | 09:09 AM
srt4ever's Avatar
srt4ever
I am running Iridiums with Gratelli wires...the ones with like 0 ohm resistance!
Purs like a kitten, no problems...
