How many miles on your SRT-4?
Old Jan 16, 2008 | 11:52 AM
MEandmySRT's Avatar
MEandmySRT
Default RE: How many miles on your SRT-4?
'05 with 21,661 and only problem is it needs about 150 more whp.
Old Jan 16, 2008 | 02:23 PM
PSI Chick's Avatar
PSI Chick
03 with 33k. only problems are the things i broke at the track.
my boyfriend has a 04 with 80k on it. he had three of his wheel bearings go out. that's about it.
Old Jan 16, 2008 | 03:43 PM
Kapitald's Avatar
Kapitald
I have i think like 42,000 on my car.....so far i have a transmission fluid leak and i think one of my O2 sensors went bad...thats about it...
Old Jan 16, 2008 | 09:06 PM
showbo's Avatar
showbo
27,1xx on my 05. Bought used in June 07 with 25,3xx. I dont drive it very often. Only problem i have had was the oil return line started leaking out of no where. Dealer covered it without question.
Oscar
Old Jan 17, 2008 | 03:29 AM
71RoadRunner's Avatar
71RoadRunner
ORIGINAL: PSI Chick
Does he autocross his '04?
Old Jan 17, 2008 | 08:10 AM
drewthatsmenb's Avatar
drewthatsmenb
05 ACR 19,034 miles the cars great the only problem right now is the tps sensor has gone bad last week but it will be replaced hopefully this weekend
Old Jan 17, 2008 | 10:49 AM
PSI Chick's Avatar
PSI Chick
ORIGINAL: 71RoadRunner
ORIGINAL: PSI Chick
yup
Old Jan 17, 2008 | 10:59 AM
blackacr's Avatar
blackacr
'05 ACR w/ 33k- 1 Clutch @ 13K, Leaking Cam seal and oil pump replaced @ 31k, and had one tokico replaced in the back. cosmetically; 1 mirror, 2 boost gauges, 2 front b-pillar covers for scratches(all replaced under warranty) I also had a "no bus" issue where the car would pick and choose when it wanted to run, but that was a result of aopenwire grounding outdue to a stereo install. (my bad)
Old Jan 17, 2008 | 03:01 PM
Cheesenip's Avatar
Cheesenip
05 with 31,489 miles. So far, Powersteering hose, Door jams repainted. Replaced the Turbo at 17k.<---dodge wouldnt cover it. They said there was nothing with the turbo. 4 bent fins and max boost at 10 psi. The TPS is starting to give me problems.
Ive broken a few things at the track but nothing major
Old Jan 17, 2008 | 03:42 PM
lblackneon's Avatar
lblackneon
Some of you guys don't do any driving.
