Brian Crower Stage 3 camshafts
Old Jan 25, 2008 | 04:38 AM
drewthatsmenb's Avatar
drewthatsmenb
Default Brian Crower Stage 3 camshafts
hey guys i bought a set of these camshafts and i just had a few questions about them i don't know if anyone has these exact ones but i'm sure someone in here woulod know a little something about them they are 272 dur. now i heard roomers that i would have to run race fuel if i put these in is this true? and also would i need a stand alone to control anything i know that i gotta get new springs and retainer but what else would i need?
Old Jan 25, 2008 | 07:55 AM
prpaster's Avatar
prpaster
Default RE: Brian Crower Stage 3 camshafts
Cam Gears
Old Jan 25, 2008 | 12:07 PM
srtgtr34's Avatar
srtgtr34
This will help:
Longer duration profile, added rpm potential. Intended for fully built engine.
Advertised Duration - 272/272 Degree
Duration @ .050" - 194/186 Degree
LIFT (Inches) - .389"/.383"
LIFT (mm) - 9.88/9.73mm
Works well with Brian Crower Spring and Retainer Kit # BC-0160
Cold Valve Lash: .000" Int / .000" Exh.
TECH TIP: Tuning and ECU mods recommended. Requires Brian Crower Spring and Retainer kit # BC-0160
From this site:
http://www.turboneonstore.com/customer/product.php?productid=421&cat=8&page=1
Old Jan 25, 2008 | 04:01 PM
drewthatsmenb
sweet thanks guys.
Old Jan 25, 2008 | 07:28 PM
Kapitald's Avatar
Kapitald
cams would be a kool upgrade??? you think it would work okay with stage 0???
Old Jan 25, 2008 | 10:15 PM
srtgtr34's Avatar
srtgtr34
i would upgrade to a stage 1 b/c of the better computer which would help with the new cam, also the bigger injectors taht come with it.
^^^^^^only if you got a cam like that^^^^^^^^^
If you were to get a cam like this then you would not need major upgrdes like that one does.
http://www.turboneonstore.com/custom...t=8&page=1
Old Jan 26, 2008 | 04:55 AM
Kapitald's Avatar
Kapitald
i have the 04 injectors equivalent to the stage 1.....and i think at one point in time my computer was reflashed...everybody else seems to think so too b/c it runs so good and never throws any bogus codes...
