i need help
Old Jan 28, 2008 | 12:25 PM
faststage02005's Avatar
faststage02005
Default i need help
when i go wot and let off a big puff of white smoke shoots out my exhaust.....what can be causing this.....it only happens when i punch it and let off the gas[&:]....
Old Jan 28, 2008 | 02:14 PM
srt4ever's Avatar
srt4ever
Default RE: i need help
I had the same problem with my 305 V-8 Trans Am...rings are going bad. At least thats my best guess, mine was also only at WOT.
Oil is going past the rings and into the exhaust/ intake system.
Old Jan 28, 2008 | 07:23 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Sounds logical..how many miles on the motor and how often/what type of oil used in the changes???
Dusty
Old Jan 28, 2008 | 08:12 PM
faststage02005
43,000miles... and i use full synthetic mobil 1 every 2500 miles....
Old Jan 28, 2008 | 09:10 PM
PSI Chick's Avatar
PSI Chick
white means the head gasket. if it was oil it would be blue smoke.
Old Jan 28, 2008 | 10:45 PM
faststage02005
thats what i thought....but yea its white smoke...how can the head gasket be causing this though?[&:]
Old Jan 28, 2008 | 11:02 PM
PSI Chick's Avatar
PSI Chick
if it's burning lol
Old Jan 28, 2008 | 11:12 PM
faststage02005
yeah.lol[8D]... ima look into changing it...thanks psi...
Old Jan 28, 2008 | 11:40 PM
faststage02005
one more question how hard is it to change it....
Old Jan 29, 2008 | 12:54 AM
drewthatsmenb's Avatar
drewthatsmenb
i'm assuming you just gotta pull the head off and i could imagine that its probably going to be a bitch [:'(]
