boost leak
Old Jan 29, 2008 | 06:59 PM
the beast14's Avatar
the beast14
Default boost leak
does anybody know where i can go to get my car checked for boost leaks here in california
Old Jan 29, 2008 | 09:16 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: boost leak
if you have an air tank / compressor, you can make 'caps' from some common items at home depot and pressurize the system and listen for th eleaks. put soapy water on the hoses and such and look for bubbles. there is a how-to floating around on this
best idea at first would be to check all your connections for tightness.
btw, why do you think its a boostleak?
Old Jan 30, 2008 | 07:34 PM
the beast14
cuz im spiking 17 psi and it drops really fast to 10 psi
Old Jan 30, 2008 | 09:17 PM
flamingpinhead
Section Moderator
what wga do you have? boost controller?
Old Jan 31, 2008 | 09:00 AM
the beast14
forward motion wga and a mbc
