i got some rookie questions
Old Feb 7, 2008 | 05:55 PM
SRT305's Avatar
SRT305
Default i got some rookie questions
I was wondering if u can put a bigger intercooler on a completely stock srt4? What gauges would i need to keep ma car properly monitered? And i may sound really dumb but wtf is a pcm lol can somebody explaine what it is n how it functions? And is a stage 2 kit good for street use? Id really appreciate it thanks.
Old Feb 7, 2008 | 07:15 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: i got some rookie questions
OK, yes you can put a bigger intercooler on the car. The PCM is the Performance Control Module, which is also sometimes called a ECM (Electronic Control Module), you can upgrade these with the StageKits. Any of theStage Units, (1,2,or 3) are fine for the street, but in Cali you may run into some emissions issues......
Dusty
Old Feb 7, 2008 | 07:21 PM
SRT305's Avatar
SRT305
k thanks so i can put a bigger intercooler on the car even if its completley stock? n What gauges would i need to properly monitor the car
Old Feb 7, 2008 | 09:31 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
yeah, you can toss a big intercooler on the car when its stock. all the i/c does is cool down the air on its waybetween the turbo and the engine. but running stock, a larger intercooler really wont benefit you very much... just look cooler. and if you get a cheapie intercooler, it could even hurt your performance causing pressure loss. make sure you read the details, a larger i/c will normally lose a little psi. also beware of cheap welding jobs and inlets/outlets. you want the air to flow through easily, not get tossed all around inside the intercooler.
stage 2 does just fine. gives the car a nice power boost
Old Feb 8, 2008 | 12:43 AM
boostneon's Avatar
boostneon
bfmic are cool loking u should get a wideband.
Old Feb 8, 2008 | 12:22 PM
NeonDon's Avatar
NeonDon
ORIGINAL: dustyloins
Dusty
Not only engine issues in Cali, cops see the big intercooler, they'll use it as an excuse to pull you over, make you pop your hood, check if you're catless and ticket you if your exhaust is too loud. If you get a ticket for a modified exhaust, you have to take your car to get inspected by the state.
Old Feb 8, 2008 | 04:49 PM
flamingpinhead
Section Moderator
ORIGINAL: NeonDon
Dusty
thats why you always keep your stock parts. you can have a back-to-stock day before going in for inspection. then have a back-to-modified day afterwards. i hate how there is such negativity surrounding modifying cars
Old Feb 8, 2008 | 05:17 PM
SRT305's Avatar
SRT305
thanks guys n whats a 50trimm thats really new to me n what are th benefits for having 1
Old Feb 8, 2008 | 05:18 PM
SRT305's Avatar
SRT305
thanks guys and whats a 50trimm thats really new to me? and what benefits do u get from having 1
Old Feb 8, 2008 | 05:30 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
ORIGINAL: flamingpinhead
ORIGINAL: NeonDon
Dusty
That's one good thing about where I live, they are lax on inspections. I don't recall ever pulling a vehicle over for a suspected violation.....but if you didn't have that front license plate on, watch out!!!!!!!!
Dusty
