newbe question
How many psi can you run on the stage zero pcm without doing damage? I am going to run the agp wastegate it says its adjustable. What can you adjust it to? Thanks for answering hopefully I didn't waste anybodys time.
everyone has to start learning somewhere. and we are the ones choosing to give our time to the forums.
the stock turbo and fuel system is only good for under 20 psi. faststage is pretty safe spiking at 18. but if you start playing with boost, just make sure your keeping track of your air/fuel ratio. leaning it out too much will be detrimental to your engine.
