Short throw shifhter install Help!!!
Old Dec 17, 2004 | 05:41 AM
fortywillys's Avatar
fortywillys
Default Short throw shifhter install Help!!!
What do i need to take apart to get the shifter in. Thx's
Old Dec 17, 2004 | 06:34 AM
Bildo's Avatar
Bildo
Default RE: Short throw shifhter install Help!!!
It was a while ago when I did it. I had the Mopar STS and if that's what you have all you need to do is take the screws out of the center console and cup holders, take off the shifter ball (just pull it off), lift the console up and off, use the claw end of a hammer to pry off the bushings from the shifter cables and then unscrew the four from the old shifter, put in the new on and put it all back together in reverse of how you took it out.
Old Dec 17, 2004 | 07:16 AM
LowSlowNeon's Avatar
LowSlowNeon
Watch out for those damn black clips that hold the shifter cables to the shifter mechanism. They are a real bitch to get off! Don't be afraid to get a little rough with them, I used a set of pliers to pull them off there. Other than that, its just like Bildo said if you have the mopar STS.
Old Dec 17, 2004 | 09:57 AM
Melody's Avatar
Melody
My husband got me a Mopar STS for christmas. I LOVE IT!!!!! Merry X-Mas to me. He said it wasn't to bad to put in except those black clips that hold the shifter cables in was a little tough to get off.
Old Dec 20, 2004 | 11:28 AM
71RoadRunner's Avatar
71RoadRunner
Yep, those are by far the hardest part which is why I recommend what someone else did, use the claw end of a hammer to pry them out.
Old Dec 20, 2004 | 05:45 PM
A10CrewChief's Avatar
A10CrewChief
I have not owned my srt-4 long and am wondering about mods is an STS a good thing to start with or would you all recomend something else?
Old Dec 20, 2004 | 05:48 PM
SRT_YA's Avatar
SRT_YA
the STS is a nice addition... it's ~$120 so the price isn't too bad... with the addition of new bushings it does make your car feel faster and cooler to drive (whether it actually helps performance I leave for others to argue)...
I recommend one... heck... I think it was the first mod I did to my car short of a K&N air filter... haha...
Old Dec 20, 2004 | 06:18 PM
A10CrewChief
Cool! thanx for the help...i was told on other forums to go for a turbo timer b-4 n-e thing. although i DO want that oh so distinct sond of th BOV too...i just dont know in which direction to start
LilSparkPlug's Avatar
LilSparkPlug
It makes your shifts so much cleaner than stock. I plan on getting one myself shortly. If you do order one, get the Booger bushings with it, youd be silly not to for the extra 20 bucks it would cost you. I want one next!! tee hee
Old Dec 21, 2004 | 08:41 AM
71RoadRunner
The Mopar STS is easily worth it and makes a big difference in it's shifting. The $120 price is the price of the STS with the booger bushings.
A turbo timer is a complete waste of money if you ask me, you rarely will even come across the situation where it would even be useful. All it does is idle the car for a preset amount of time after you park it and shut it off. The only times where you need to let it idle before shutting it off is after running it hard, AKA: right after a race, or when you have been at freeway speeds and get to your destination immediately after getting off the freeway. If you hit a red light or two after getting off the freeway before reaching your destination, then you don't need to let it idle since it did while sitting at the light. Check in your owners manual, it gives you scenarios and cool down times for each if any at all. In normal driving you do not even have to let it idle to cool down, this was really just a problem with non-intercooled turbo cars to begin with. The intercooled turbos run much cooler and they also cool down far quicker, it works even better with CAI. The only time I see a turbo timer being worth the time, money and effort to install is if you take your car to the track and run it very often.
