SERIOS PROBLEM
Old Mar 1, 2008 | 01:14 PM
BOISEBLUE's Avatar
BOISEBLUE
Default SERIOS PROBLEM
OK AS HARD AS THIS IS TO EXPLAIN, ILL GIVE IT MY BEST SHOT. SO AFTER A TOTAL REBUILD AND INSTALLING BIGGER INJECTORS EVERYTHING SEEMED FINE. UNTIL SHORTLY AFTER IT BEGAN TO MISS FIRE (NO CODES). NOW IT STUTTERS REALLY , REALLY BAD AND AS IT WARMS UP IT GETS WORSE. THE ONLY THIS WE CAN THINK IS IT MIGHT BE THE PUMP( WHICH I BELIEVE IS STOCK) GOING OUT CAUSE OF THE BIGGER INJECTORS. ALSO WHEN WE REV IT UP IT SOUND ALOMOST LIKE A SUBARU, LIKE CHOPPY NOT A CLEAN REV AT ALL. LET ME KNOW WHAT YOU GUYS THINK. THANKS ALOT!!!
Old Mar 1, 2008 | 02:47 PM
Burnnout's Avatar
Burnnout
Default RE: SERIOS PROBLEM
Need more info on the car.... what are your mods ?... anything other than listed in your sig ? ..with the mods listed you wouldn't be safe running over 17-18psi....
Old Mar 1, 2008 | 03:10 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
and please do turn off the caps locks. thanks
Old Mar 1, 2008 | 03:44 PM
BOISEBLUE's Avatar
BOISEBLUE
umm yeah sorry about the caps, im at work and it has to be on. anyways why would itnot be safe to run that much boost???
Old Mar 1, 2008 | 10:28 PM
Kapitald's Avatar
Kapitald
because it doesnt look like you have the necessary fuel modifications.....
good job on the injectors you need those....
you will also need a fuel return line kit (with a pressure regulator of course)...and upgrade that fuel pump...especially with that 50 trim...
Old Mar 2, 2008 | 10:48 PM
scox1026's Avatar
scox1026
Thats strange that it isn't throwing any codes...??
Old Mar 3, 2008 | 10:10 AM
faststage02005's Avatar
faststage02005
i say fuel pump mine did the same thing...
Old Mar 4, 2008 | 01:02 PM
BOISEBLUE's Avatar
BOISEBLUE
Yes!!!! i got it hahahah. my spark plug wire had a hole in it and was arching really bad. im so happy its not as bad as i thought.
Old Mar 4, 2008 | 02:00 PM
srt4ever's Avatar
srt4ever
Good...glad to here she's runnin strong!
Old Mar 5, 2008 | 03:47 AM
Kapitald's Avatar
Kapitald
wow cool your running that setup with just injectors??? nice to hear its running good..
