Fidanza Adjustable Cam Gear for 03-05 SRT-4
should i get them ..i wanna kno if its owrth getitn nd wat will it do..
my mods are...mods: 3 inch downpipe,3 inch o2 housing, mopar exhuast. cold air intake. stage 2 wastegate, boost controller, agp motor mounts, agp tranny mount, halo head lights, boost controller, trubo xs rfl..
i wanna kno if itll do a big differencea nd if worth getting
theyallow for complete and total adjustment of timing of the cams. This allows you to fine tune and extract every last horsepower lurking in your engine. These are also lighter then stock and help to reduce that ever important rotating mass. These also help when timing changes occur due to head milling/decking.
The gears allow for a total of 20 degrees adjustment and are etched in 1 degree increments.
i would say that their one of the last mods you should do... i dont think they are very necessary unless your running huge HP.
what everyone else already said. they're not worth it unless you're trying to good power. also, i would not EVER buy the fidanza's. they're freaking pos gears. if anything get unorthodox.
ORIGINAL: PSI Chick
ORIGINAL: PSI Chick
i think that this might be a problem lol
[IMG]local://upfiles/3729/1F04446DD9A34292833C7AEEE78671FA.jpg[/IMG]
Did you get new cam gears yet?
I wont be buying any more of those.
Trending Topics
yea i have the unorthodox now, no problems at all with them. i'm also by far not the only one that has had that happen with the fidanza, and yet fidanza refuses to admit that there's a problem lol
