TPS Update
Old Mar 20, 2008 | 12:41 AM
drewthatsmenb's Avatar
drewthatsmenb
Default RE: TPS Update
ok i installed the new tps today which i got for free by the way i bought the new one and returned the old one b/c i'm just that good lolhowever it did but didn't fix the problem the car doesn't drive itself anymore and the car actually sounds like an srt-4 again but the idle bounces around when the car heats up and its driving me mad. i noticed that if i get on it the car won't do it as much it'll do it for like a second or two then stop but if i drive it easy it'll do it the whole time i'm stopped. what the hell is going on? and if it is my IAC which it sounds like it really could be where can i get a new one?
Old Mar 20, 2008 | 01:21 PM
Kapitald's Avatar
Kapitald
IAC??
Old Mar 20, 2008 | 04:50 PM
drewthatsmenb
Idle Air Control valve/motor
Old Mar 20, 2008 | 08:52 PM
LilSparkPlug's Avatar
LilSparkPlug
Kapiltad: Thats just the axle seal, replacing it is a medium difficulty level but if its not pressed in properly it will leak again. Its also much easier to do on a lift than anywhere else. Oh and thanks for the compliments on the car in the other thread.[/align][/align]drewthatsmenb: When you did the TPS wiring kit, how far down the harness did you go? The IAC can be had from a local dealership. When the car is idling, wiggle the IAC wires, then the TPS wires, see if that fixes the conjumbled idle you are experiencing.[/align]
Old Mar 21, 2008 | 01:00 AM
drewthatsmenb
i went about 10 inches down then cut and sawtered the new wires in
