no idea whats wrong
Old Mar 23, 2008 | 08:54 AM
grattonp's Avatar
grattonp
Default RE: no idea whats wrong
problem fixed thanks guys left ic pipe was right off now its running arround 7 psi still low isnt it?
Old Mar 23, 2008 | 11:19 AM
AWH's Avatar
AWH
Yeah 7 PSI is low. Stock they usually boost between 12-15 psi. Are you using premium gas when you fill up? What is the octane rating?
Try disconnecting the battery then reconnecting to reset the computer. See what happens. Is the CEL still coming on?
Old Mar 23, 2008 | 07:21 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
yeah, you still may be leaking somewhere else as well. if the ic was completley off its possible other connections came loose also. what gear is the 7psi in? you wont see as much boost in 1st. get up to speed and use 3rd for a better measure of where your spiking / holding.
morning thought on this one:
is the spring not a 7lb? so if the wga is busted it would only hold 7psi...
