MAP sensor?
just wondering... is the stage 2 & 3 map sensor and TIP sensor required if you are running boost at or over 16 psi? i didnt go with the stage kits, i went with the bolt on plan, 3" turbo back exhaust, cold air intake, stage 1 pcm, stage 2 injectors, greddy boost
controller...
thanks..
controller...
thanks..
You don't want to swap to the S2/3 MAP & TIP unless you have some way to tune the fuel (a "piggy back" fuel computer).
The S2/3 MAP & TIP are too far off to just plug them in to the stock or S1 ECU; you'll run lean.
