What to do next??
Old Mar 29, 2008 | 06:26 PM
stocksrt4's Avatar
stocksrt4
Default What to do next??
I am wondering what i should do next to my car for more HP? I have 3' corsa full exhaust with K&N cold air intake and a 3" maxxfab dp..I also have a manual boost controller and a APG actuator.. i also have mopar plugs and wires. So what can i do next to add more HP to my car?? hopefully to were i can tell it helps
Old Mar 29, 2008 | 07:30 PM
LilSparkPlug's Avatar
LilSparkPlug
Default RE: What to do next??
That all depends on how much you want to spend and where you want your car to be. To start off small, a Stage 1 PCM and a throttle body, larger injectors (S2) and a map clamp. Or go big turbo...
Old Mar 29, 2008 | 08:51 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Good info!!!!!!!!!!!
Dusty
