Where do i put Injectors PLease HELP
Old Mar 30, 2008 | 10:36 PM
stocksrt4's Avatar
stocksrt4
Default Where do i put Injectors PLease HELP
Can someone give me installation instruction on stage one injectors i just bought them and figured i could get some help on here!!
Old Mar 30, 2008 | 11:20 PM
PSI Chick's Avatar
PSI Chick
Default RE: Where do i put Injectors PLease HELP
stage 1's? if you have a 04/05 you have those stock.....
but if you need to change or check them, it's pretty easy.
remove the injector cover
unbolt the retainers from the block
disconnect the clips from the injectors (pull the metal tabs off then take the plastic clips off)
pull the rail off (the injectors will come off with it usually, if not then just pull them off)
clean the holes for the injectors and make sure nothing gets in them
remove the old injectors from the rail
put the new ones on the rail
put some vaseline on the o-rings on the new injectors
put the injectors and the rail back on the car
bolt on the rail
put the injector cover back on
that's really about it....
Old Mar 30, 2008 | 11:46 PM
stocksrt4's Avatar
stocksrt4
ok thank you very much
Old Mar 31, 2008 | 06:44 AM
byebye's Avatar
byebye
Just a note on initial removal. Use some compressed air and blow around the injector ports before removing the injectors. Dirt and rocks get in there(not sure how) and you don't want any of that to fall in or inhibit a good seal on the injector.
Kris
Old Mar 31, 2008 | 10:10 AM
LilSparkPlug's Avatar
LilSparkPlug
A good idea also, so you don't wear your 93 octane is to remove the fuel pump relay from the engine bay PDC. Start the car and let it run until it dies. Then the rail will be free of excess fuel.
