Stock SRT-4 injectors specs?
Old Mar 31, 2008 | 11:44 PM
diegom6's Avatar
diegom6
Default Stock SRT-4 injectors specs?
Hi guys,
long time I bought 6 injectors on ebay that were fro the SRT-4 stage 1 as the previous owner stated. I barely remember the size and sopously it's 554cc.
Anyways if someone has the correct info for it I will aprreciate it.
lb/h or cc @ fuel press
High impedance
Who runs Mega Squirt with these? What's it's the correct injector opening time with MS II extra code?
Thanks,
-Diego
Old Apr 1, 2008 | 10:14 AM
PSI Chick's Avatar
PSI Chick
Default RE: Stock SRT-4 injectors specs?
577cc@58psi
Old Apr 1, 2008 | 10:31 AM
diegom6's Avatar
diegom6
Thanks PSI Chick
NOw I would like to know if someone over ehre run the MS II with these injectors...would like to know what's the injector opening time for these lil bad boys.
Thanks,
-Diego
Old Apr 2, 2008 | 09:43 AM
PSI Chick's Avatar
PSI Chick
no one on this board is running megasquirt. i only know of one person who is running it, but he's using 750cc's. honestly you're not going to find anyone using a non-plug and play ems on stock injectors, it's just too much work for too little gain. everyone running the ms is going to be on 750's or higher.
Old Apr 2, 2008 | 10:03 AM
diegom6's Avatar
diegom6
I see, are these 750cc injectors MOPAR/SIEMENS as Mopar upgrade performance part? Or it's just other brand? IF it's Mopar and that guy runing MS on his SRT-4 these injectors would be nice to know the injector opening time.
Anyways...thanks for your help!
-Diego
Old Apr 2, 2008 | 11:30 AM
PSI Chick's Avatar
PSI Chick
they're rc engineering injectors, and actually are rated at 43psi rather than the 58 that mopar uses (never understood that one lol).
