BoosT ProBLEM!!! HeLP Plz
Old Apr 6, 2008 | 12:15 AM
Kapitald's Avatar
Kapitald
Default RE: BoosT ProBLEM!!! HeLP Plz
well...do you have a boost controller....is it turned up too high....i know if i open up my boost controller i can peg way past 20 psi becuz the wastegate wont open....but i also know its pointless to go that high so mine is turned down...you need to find out why ur wastegate isnt opening up...
Old Apr 6, 2008 | 09:21 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
perhaps your wga is broken? you said it works fine w/ the stock one, right?
Old Apr 6, 2008 | 05:27 PM
T_U_R_B_O's Avatar
T_U_R_B_O
only way itworks with the stock wga isif i route the lines the way they came from factory.. if i t the green or blue line to the stock wga it does the samething
Old Apr 7, 2008 | 02:47 AM
STILL GH3TtO's Avatar
STILL GH3TtO
try not "t-ing" it up
Old Apr 7, 2008 | 04:07 PM
T_U_R_B_O's Avatar
T_U_R_B_O
what do u mean by not t'ing it up??
