Stage 1 on the way!
Old Jan 6, 2005 | 12:52 AM
glhs837's Avatar
glhs837
Default RE: Stage 1 on the way!
Released just today for ordering, no S2 yet, should be soon. Website most likely just not updated. Call'em they will take care of you.
Old Jan 6, 2005 | 01:04 AM
NeonOrngBlast's Avatar
NeonOrngBlast
I think i will wait for stage 2 i want the toys and dont want to drop the cash twice.
Old Jan 6, 2005 | 01:27 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
You'll enjoy it!!!! Try combining it with a Mopar/Borla exhaust and a K&N intake or filter and you'll be putting out at least 10 more ponies on the dyno .....and my dealer has given me NO hassle about warranty work with these mods........which is great since I bought the extended warranty.
Old Jan 6, 2005 | 05:21 AM
71RoadRunner's Avatar
71RoadRunner
I still need to get around to ordering my Stage 1 as well as installing my pressure pipe and gauges and ordering the rest of the exhaust and....
Old Jan 6, 2005 | 09:42 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Did you make those your New Year's Resolutions?????
Old Jan 6, 2005 | 10:24 PM
SRT4LVR's Avatar
SRT4LVR
Now I feel like an idiot. I thought when you bought the car (mine is a 2004 silver SRT4) it was already a stage 1. [sm=smiley24.gif]
Old Jan 7, 2005 | 12:00 AM
NeonOrngBlast
No the 04 and 05 have the injectors already where the 03 does not so they get another part for stage 1 where the 04 and 05 dont. That must be where you were thinking it had it already.
Old Jan 7, 2005 | 02:56 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Not to worry, it just makes your install go that much faster!!
Old Jan 8, 2005 | 12:21 AM
SRT4LVR's Avatar
SRT4LVR
Hmmm...I have already gotten pulled over once [sm=headbang.gif] How much does it cost for the stage one and does it void out your warranty?
Old Jan 8, 2005 | 12:40 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
The cost varies a little depending on who you buy it from. You'll have to furnish your VIN and estimated mileage at install time when you order and you can figure on about a 2 week wait while they flash your PCM to your particular vehicle. I paid about $330 for mine.
Install is pretty easy, remove negative battery terminal cable, remove the airbox, unplug the old PCM, plug in the new one, replace airbox, replace negative battery terminal cable (I'm assuming you have a 2004 SRT-4).
Drive the SRT-4 around for a little while to let the PCM "learn" the car and you're in business....
My dealer once told me the Stage 1 would "void out the turbo" and when I looked at him funny he mumbled that any problem the Stage 1 causes would not be covered under the warranty (I have the extended warranty!!!). After several questions from me he admitted it would be almost impossible to prove a Stage 1 PCM "caused" a failure of another part......too many other variables come into play.....
I've taken it in for warrenty work with the Stage 1 installed, plus the Mopar/Borla exhaust and haven't had any problems/questions/comments....
