Lorenzo TB pics
RE: Lorenzo TB pics
not that much is involved. you don't have to change anything else, and lorenzo has very detailed directions that make it easy to change it yourself. the only tricky part is the tps sensor, but even that it's too bad as long as you're careful when removing it.
lorenzo has reported 14hp gains with his set up if i remember correctly, but people have said that it's a low number. i can tell you more definetly after i go to the dyno. there is much better throttle response with the new piece in, and faster spool as well.
RE: Lorenzo TB pics
ok update now that i had a chance to really test this thing out last night. the butt dyno is definetly happy!!! before the tb, i would get a little hesitation around 3-5 psi before it would climb up, and it was a gradual climb. now i hit the gas and it's just like bam! 20 psi in an instant. no hesitation, no studder, nothing. it just goes like hell. it's awesome!!! definetly a must buy
Trending Topics
RE: Lorenzo TB pics
I have been wanting to get a larger throttle body. I'm suprised that the Iceman TB is having issues, I wonder if they've fixed it. My only concern with the Lorenzo is that it has a lighter pedal feel, seems like it might be more prone to hanging open, do they have something to fix that? I like decent pedal feel, not too light or too stiff, but more to the stiffer side. I'll just have to wait and see what comes of the throttle bodies out there before I choose one.
RE: Lorenzo TB pics
roadrunner, that is not a problem with lorenzo's tb's. he has been making these for a while now for other gen neons, and has never had that happen. the srt tb was tested for about 6 months before ever released to ensure that everything was fine.
it is slightly lighter than the stock petal, but you get used to it very fast. the only thing i have to watch now is that when i give it gas it responds a lot quicker now then before, so i have to watch at lights and things that i don't take off like a madwoman! i'm sure that i'll get used to it soon enough and that won't be a problem shortly
