brake fade
Old Apr 18, 2008 | 10:28 AM
mopar222's Avatar
mopar222
Default brake fade
Been having a problem with brake fade at the track, running hawke hp+ pads, but they still are fading. Running at Road America and acc in joliet. I believe it is due to heat. My question is, How do I cool the brakes, which is the best way. Also the power steering trouble code comes on at the track, not on the street. It seems to only come on when I am using the hight rpms, keeping it under 5600rpms does not throw a code. Any advice is helpful, thanks.
Old Apr 18, 2008 | 10:41 AM
prpaster's Avatar
prpaster
Default RE: brake fade
What kind of Rotors are you using
Old Apr 18, 2008 | 12:11 PM
mopar222's Avatar
mopar222
Stock, don't think there is a need for slotted or drilled, other cars are running smooth with no problems. I am running motul 600 brake fluid, so that should not be the problem either.
Old Apr 18, 2008 | 06:13 PM
PSI Chick's Avatar
PSI Chick
hum..i was just gonna say fluid. the hawk pads though aren't really a track pad, they're a street pad. that's probably why you're getting so much fade. try a race pad like the porterfields
Old Apr 18, 2008 | 09:01 PM
taekwon11's Avatar
taekwon11
More than likely the pads you are running are not designed for optimum braking at the tempature they are reaching on a roadcourse. I run Porterfield R4's on mine and they are fine. Unfortunately, they don't get hot enough to use on the street, so I change my pads and rotors out for the track/street. I have been told that once a can or bottle of brake fluid is opened you must use it or throw away anything you don't use, because it will get contaminated so you may also want to make sure that you always open a fresh can/bottle whenever you add brake fluid. I am sure it is much more critical when you are tracking your car. Hope this helps.
Old Apr 21, 2008 | 01:52 PM
srt4ever's Avatar
srt4ever
Brake fluid in hydroscopic...it loves moisture!
Old Apr 22, 2008 | 09:43 AM
mopar222's Avatar
mopar222
Thanks for the info, but I still am wondering if there is a brake cooling kit out there for the srt4? Or is there a good setup that can be made for the srt4?
Old Apr 22, 2008 | 09:58 AM
mopar222's Avatar
mopar222
Not all brake fluids absorb moisture. DOT5 is silicon based and does not. And I believe it is safe on paint.
Old Apr 22, 2008 | 05:32 PM
Plan B's Avatar
Plan B
That's interesting, the guys I know that run the HP+'s seem to like them.... I was going to say brake fluid as well, but have heard good things about the Motul. Maybe try the ATE Super Blue and a set of Carbotech XP8's or XP10's? Definately not the rotors though. Stock are more than enough....
