IAC Valve Issue
Old Apr 21, 2008 | 10:38 PM
dparsons06's Avatar
dparsons06
Default IAC Valve Issue
Earlier my car just went down to 500RPM and felt like it was going to die and the check engine light came on, i had a friend scan for the code and it came up sayin Something wrong withthe IACValve. Has anyone else had this issue or know what to fix?
Old Apr 24, 2008 | 10:53 PM
drewthatsmenb's Avatar
drewthatsmenb
Default RE: IAC Valve Issue
did it only do it once or is it still doing it?
Old Apr 25, 2008 | 12:42 AM
dparsons06's Avatar
dparsons06
So far only once
Old Apr 25, 2008 | 10:54 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
if it has not done it before or since then, you might just not worry about it. just a little hiccup for your car.
