AEM Wideband gauge
Old May 1, 2008 | 06:54 PM
  #21
Plan B's Avatar
Plan B
Default RE: AEM Wideband gauge
Wow, didn't hold w/ 103!?!? Were you on PCM controlled boost? All vaccuum lines/sensors hooked up? Thereare at least three of us w/ S2 w/ toys that run HOM on 94 regularly on and off the track
Old May 3, 2008 | 05:13 PM
  #22
Moparmatt440's Avatar
Moparmatt440
Yea everthing is hooked up, I was on dab 3 and half way the light started to blink. My mbc was not in when I raced. I have just the 92 in it now, I'll get octane boost soon, but yea, I'll try it again, but next time I am going to go with the 109 VP.
Old May 3, 2008 | 06:02 PM
  #23
PSI Chick's Avatar
PSI Chick
that's what i'm saying. it's not normal to be able to hold hom w/94. i had to use torco to hold, not even with meth alone on pump would hold it. now i can hold with a mix of meth and 109 minimum, but i usually use c16. not that it matters anymore, no more hom for me!!!
Old May 5, 2008 | 03:40 PM
  #24
Plan B's Avatar
Plan B
ORIGINAL: PSI Chick
But that was on S3, no? S3 appears to be very picky. However, a friend of mine can hold HOM on the 94 + Meth w/ his S3....Weird....
Old May 5, 2008 | 04:37 PM
  #25
PSI Chick's Avatar
PSI Chick
i had s2 before s3, and it did not hold on pump with w/i then either. i always used C16 and never had a problem with it. s3 is much pickier than s2 is, but even then i was a pain. i'm so glad that i don't have that issue anymore lol.
