motor mount inserts
I am selling the car, so I do want to put in soild motor mounts. I have been looking online and see inserts for the dogbones and inserts for the transaxel mount. Should I get both or will the dogbone ones be enough?
Are these pretty easy to install? What tools are needed?
Mods: Mopar Tru cold air intake, Mopar Stage II turbo upgrade, Mopar blow-off plate, MSD coil pack, New Ported & polished head, Brian Crower Stage II street/strip cams, Fidanza cam gears, Titanium springs & retainers, Fat Boy Racing large front mount intercooler, Borla cat-back exhaust, Apex turbo timer,KYB struts with Eibach lowering springs, drilled and dimpled rotors, ceramic brake pads
You just need a socket set and some box wrenches. it was pretty easy. The transmount is the hardest for a first timer. I now have solids and my inserts are collectind dust. You do need washers for them. The install shouldn't take more than 30 min.
You'll notice a difference right away.
Kris
Kris
