what other neon/ non neon rims will fit an srt-4?
Old May 8, 2008 | 03:08 PM
luissrt4's Avatar
luissrt4
Default what other neon/ non neon rims will fit an srt-4?
i need to find a set of rims that will also fit my srt-4 so i can finally put drag radial on it & run it next week on the track.
im new to this so i would really apreciate a response.. thanks
Old May 8, 2008 | 07:03 PM
LilSparkPlug's Avatar
LilSparkPlug
Default RE: what other neon/ non neon rims will fit an srt-4?
1995-1999 Dodge Stratus Steel wheels are 5x100 with an offset that clears. Jetta, Bug and Passat steel wheels are also 5x100 and clear.
Old May 8, 2008 | 09:24 PM
luissrt4's Avatar
luissrt4
hey another question ma boy got som z24 rims 5 star ther 5/100 too so i guess they will fit 2
Old May 10, 2008 | 09:48 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
dont only be concerned about the bolt pattern. dont know about the Z rims, but gotta make sure the offset is correct and they will clear the callipers and all. best way is if you can, try em on and see if they fit before you buy.
Old May 11, 2008 | 02:32 PM
LilSparkPlug
No they don't fit. I have Cavalier steel wheels on the rear of the car but they won't clear the calipers in the front. Its the offset that matters. Usually +35 to +40 depending upon the style of the wheels.
