exactly how much boost...?
Old Jan 13, 2005 | 03:00 AM
200srt4's Avatar
200srt4
Default exactly how much boost...?
how many pounds of boost is a stock SRT-4 giving out?
Old Jan 13, 2005 | 04:04 AM
LilSparkPlug's Avatar
LilSparkPlug
Default RE: exactly how much boost...?
I'm stock and in the cold weather right now I'm running anywhere from 11-15psi
Old Jan 13, 2005 | 07:46 AM
71RoadRunner's Avatar
71RoadRunner
It depends greatly on the weather and temperature, it can be from 11-15 PSI, lower in the colder weather and higher in the warmer. It can run as high as 15 PSI stock.
Old Jan 13, 2005 | 01:09 PM
mebigsexymatty's Avatar
mebigsexymatty
highest ive seen is 11 PSI, but the warmest its gotten here is 35 since ive had my car [>:]
Old Jan 13, 2005 | 03:17 PM
Dodge4SRT's Avatar
Dodge4SRT
I usually boost from 11-14 PSI.
Old Jan 14, 2005 | 02:09 AM
200srt4's Avatar
200srt4
thanks alot
Old Jan 16, 2005 | 04:16 AM
71RoadRunner
I usually get more boost than that at 35, but each one is a little different and 11 psi at that temp isn't that bad. Wait until it warms up and see how it does come spring/summer.
