Why do I have Oil in my pipe?
Old May 15, 2008 | 10:51 AM
srt4ever's Avatar
srt4ever
Default RE: Why do I have Oil in my pipe?
None...just a K&N filter in the box and a MOPAR BOV...thats it.
Old May 16, 2008 | 01:32 PM
Kapitald's Avatar
Kapitald
hmmm??? i wouldnt think a stock srt-4 would have PTB that bad...usually when your running more boost....
still thats what it sounds like..
Old May 17, 2008 | 09:37 AM
PSI Chick's Avatar
PSI Chick
what kind of boost are you seeing?
Old May 17, 2008 | 04:45 PM
srt421's Avatar
srt421
i was having that same problem with the compressor surge turns out i had a vacuum line that was about half off and was leaking put it back on and a zip tie to make sure it doesnt come off again and now my baby is running fine no spikes in boost or anything
Old May 17, 2008 | 04:47 PM
srt421's Avatar
srt421
also about the oil blow by watch out one of my friends had his charge pipe pop off because of the oil gettin there
Old May 17, 2008 | 04:53 PM
PSI Chick's Avatar
PSI Chick
pipes pop off because clamps are loose, not because of oil.
Old May 20, 2008 | 02:29 PM
monstab757's Avatar
monstab757
^^lol, tru dat. I just recently ditched my catch can. I had a homemade one and it was a pain in the *** to mount it and where it was mounted always made it difficult to empty. Didn't feel like spending $100 on a namebrand one so I just left it off.
Old May 20, 2008 | 02:32 PM
Plan B's Avatar
Plan B
ORIGINAL: VTSRT4
I thought blow by could possibly blow the turbo or is a sign that the turbo is about to blow?
If the oil is in the exhaust, sure. White smoke = bad times
Old May 20, 2008 | 02:40 PM
PSI Chick's Avatar
PSI Chick
white smoke usually means that the head gasket is blown. if the seals on the turbo are shot and oil is being burnt in the exhaust the smoke will be blue.
Old May 20, 2008 | 03:01 PM
Plan B's Avatar
Plan B
You are exactly right, my mistake.... i was thinking about that as I was out on my smoke break, you just beat me to my edit, lol
