Stage 3 Information sheet
Old Jan 16, 2005 | 04:00 PM
casper's Avatar
casper
Default Stage 3 Information sheet
Stage 3R Turbo Upgrade Kit Components
• (1) Stage 3R PCM
• (4) 682 cc/min Fuel Injectors*
• (1) 3.0 bar MAP Sensor*
• (1) 3.0 bar TIP Sensor*
• (1) Block-off Connector for PCM
• (1) Mopar TD05HR Turbocharger Assembly (with integrated
exhaust manifold) and Penta-flange Exhaust Elbow
• (1) Demand-regulated Fuel Rail Assembly
• (1) 180 lph Fuel Pump Module
• (1) Fuel Rail Regulator Hose Kit
• (1) Exhaust Manifold Gasket
• (1) Exhaust Flex Joint Gasket
• (7) Exhaust Manifold Bolts
• (6) Oil/Water Banjo Fitting Sealing Washers
• (1) Oil Return Line Gasket
• (1) Vacuum Harness Securing Kit
* Not included in the Stage 2 to Stage 3R
Upgrade Kit (P4510339).
Recommended Upgrades
• P4510647 Performance Clutch
• P4510548 Blow-off Valve Conversion Kit
• W Speed-rated Tires
• P4510461 Cat-Back Exhaust System
• NGK #4306 Spark Plugs (or equivalent)
• Spark Plug Gap of .035"–.040"
Stage 3R Turbo Upgrade Kit Feature Description
• Mopar TD05HR Turbocharger. The Stage 3R kit uses a
TD05HR-15GK2-10cm2 turbo. The compressor and turbine
are larger than the production turbo to produce higher
power more efficiently.
• Ti-Al Turbine Wheel. The Mopar TD05HR Turbocharger
employs a low mass Titanium Aluminide (Ti-Al) turbine
wheel that has less rotational inertia. Less inertia results in
better turbocharger response.
• Increased WOT and Part Throttle Boost. To develop the
impressive peak power and peak torque for the Stage 3R
package, the boost pressures have been optimized for
wide-open throttle (WOT) conditions. The boost was also
recalibrated for part throttle conditions to enhance the
drivability.
• Boost Hold Feature During WOT Shifts. Keep the pedal to
the metal, blip the clutch, and grab the next gear. Do it fast
enough before the redline, and your reward will be a
zero-lag, constant boost shift.
• More Aggressive Exhaust Note During Deceleration. More of
the Mopar signature pops, snaps, and burbles during
closed throttle decelerations and between shifts.
• Optimized Calibration for the Mopar Performance Blow-Off
Valve (sold separately). The Stage 3R kit has improved the
functionality and the audible performance of the integrated
recirculation valve with the BOV Conversion Kit in mind.
• Increased Rev. Limit. The Stage 3R calibration increases the
engine redline from 6240 RPM to 6500 RPM.
SRT-4 Engine Performance Chart
Vehicle Package Torque Rating Power Rating
SRT-4 Stage 3R 325 ft-lb @ 3200–4800 rpm 310 hp @ 5600 rpm
SRT-4 Stage 3R 365 ft-lb @ 3200–4800 rpm 355 hp @ 5200 rpm High Octane
NOTE: ALL RATINGS ARE WITH CAT-BACK SYSTEM P4510461.
Mopar Performance parts are sold “as is,” without any
warranty whatsoever.
Implied warranties, including warranties of merchantability
or fitness for a particular purpose, are excluded. The entire
risk as to quality and performance of such parts is with the
buyer. Should such parts prove defective following their
purchase, the buyer and not the manufacturer, distributor or
retailer, assumes the entire cost of all necessary servicing or
repair. Chrysler, Dodge, and Jeep® vehicle and parts
warranties are voided if the vehicle or parts are used for
competition or if they fail as a result of modification.
INFORMATION SHEET
STAGE 3R TURBO UPGRADE KIT
2003-2004 DODGE SRT-4
PART NUMBER P5007864 (with Turbo Toys)
P4510338 (without Turbo Toys)
P4510339 (Stage 2 to Stage 3R Upgrade Kit)
K68587011 10/01/04 Page 1 of 2
©2004, DaimlerChrysler Motors Company, LLC. Mopar is a registered trademark of DaimlerChrysler Motors Cmpany, LLC. All rights reserved.
SPECIAL NOTE:
P0633 Fault Code Explanation
It is normal for the Mopar Turbo Upgrade Kits to set the
P0633 fault code. This code will not activate the MIL
(Malfunction Indicator Light), but it will be displayed during a
diagnostic check. The vehicle functionality or performance
will not be affected as a result of this code.
Fuel Line Pulsation Resonance Explanation
It is normal for the Mopar Stage 3R Turbo Upgrade Kit to
exhibit fuel line pulsation resonance at idle and low engine
loads. This condition is characterized by an audible “tapping”
noise emanating from the fuel system, particularly in the area
of the fuel line leading from the firewall to the inlet of the
demand regulated fuel rail. This condition is normal and is
generated by the fuel pressure regulation system at low
injector pulse widths. Vehicle functionality and/or
performance will not be affected as a result of this condition.
Not legal for use on pollution-controlled vehicles or vehicles
registered for highway use.
For technical assistance regarding the MOPAR Turbo
Upgrade Kits, please call the Mopar Performance Tech
Line at (248) 969-1690.
INFORMATION SHEET
K68587011 10/01/04 Page 2 of 2
NOTE: MOPAR PERFORMANCE PARTS RECOMMENDS PROFESSIONAL INSTALLATION BY AN ASE CERTIFIED
TECHNICIAN. A VEHICLE HOIST, TELESCOPING TRANSMISSION JACK, TORQUE WRENCHES AND SPECIALIZED REMOVAL
AND INSTALLATION TOOLS ARE REQUIRED. VEHICLE SERVICE MANUALS HAVE BEEN PROVIDED AND ARE REFERENCED
EXTENSIVELY DURING THE INSTALLATION PROCEDURE. REFER TO SECTION 0 (STANDARD PROCEDURE – HOISTING
RECOMMENDATIONS) FOR VEHICLE LIFTING INFORMATION, AND REFER TO THE FRONT OF EACH SECTION FOR SPECIAL
INSTRUCTIONS AND WARNINGS.
Installation Procedure
(1) Release fuel system pressure per Section 14 (Standard
procedure – fuel system pressure release)
(2) Disconnect battery and remove battery tray per Section 8
(electrical/battery system/battery – removal)
(3) Drain engine coolant per Section 7 (Standard procedure
cooling/engine)
(4) Drain engine oil and remove oil filter per Section 9
(Standard procedure – engine and oil filter change)
(5) Review standard procedures and Section 14 to become
acquainted with the fuel lines, hoses and clamps and fuel
quick connect fittings.
(6) Remove air cleaner assembly per Section 9 (Engine/air
intake system/air cleaner housing – removal)
(7) Disconnect the vacuum hose harness from the
turbocharger per Section 11 (Solenoids and vacuum
harness – removal), and lay aside
(8) Remove Powertrain Control Module per Section 8e
(Powertrain control Module – 2.4L SRT-4 – removal)
NOTE: THE ELECTRICAL CONNECTORS FOR THE PCM ARE
COLOR CODED.
(9) Install new Stage 3R Performance Module per Section 8e
(Powertrain Control Module – 2.0L – installation)
NOTE: DO NOT REPLACE THE AIR CLEANER HOUSING OR
CONNECT THE NEGATIVE BATTERY CABLE UNTIL THE END OF
THE INSTALLATION (FINAL INSTALLATION CHECKS AND
STARTING PROCEDURE).
(10) Remove fuel rail and injectors per Section 14 (Fuel
rail – removal)
NOTE: IF YOU ARE UPGRADING FROM STAGE 2 USING KIT
P4510339, YOU WILL REUSE YOUR MOPAR PERFORMANCE
FUEL INJECTORS, MAP SENSOR AND TIP SENSOR.
(11) Install Stage 2/3 Mopar Performance Injectors to the fuel
rail assembly per Section 14 - Fuel rail installation.
(12) Install Fuel Rail Assembly per Section 14 (Fuel rail –
installation). Refer to Fig. 1 for proper orientation of
vacuum port on the new Demand-Regulated Fuel Rail.
Fig. 1 Vacuum Port Orientation
(13) Install Fuel Pressure Regulator Vacuum Line.
A. Locate the throttle body vacuum elbow connection
located just ahead of the throttle body (Fig. 2).
Inspect all connections. Repair or replace any
damaged components before proceeding.
Fig. 2 Throttle Body Vacuum Elbow Location
B. Disconnect the 1/8" vacuum hose from the vacuum
tee in the area indicated (Fig. 2) by gently twisting
the hose while pulling apart.
INSTALLATION INSTRUCTIONS
K68587011 10/01/04 Page 1 of 6
C. Using the 1/8" vacuum hose supplied, cut a 50 mm (2 inch)
section of hose and install over straight leg of the vacuum
tee (Fig. 3).
Fig. 3 Vacuum Tee Installation
D. Install the straight leg of the supplied barbed vacuum
tee between the two hose ends (Fig. 4).
Fig. 4
E. Using the remaining length of 1/8" vacuum hose
supplied, connect one end to the remaining leg of
the vacuum tee (Fig. 4) and carefully route the hose
to the fuel pressure regulator located in the center
of the Demand-Regulated Fuel Rail Assembly (Fig. 5).
Make sure to route the hose away from sharp
edges and avoid pinching or kinking the hose
during reassembly. Trim excess hose material with
diagonal cutters.
Fig. 5 Hose Routing–Demand-Regulated Fuel Rail Assembly
F. Connect the free end of the hose to the fuel pressure
regulator (Fig. 5).
G. Starting at the fuel pressure regulator connection,
secure all flexible rubber hose connections outlined
in steps A-E above, using the zip ties supplied. Trim
excess material from zip ties using diagonal cutters
for a clean installation.
(14) Drain fuel tank per Section14 (Standard procedure –
drain fuel tank).
(15) Remove fuel tank from vehicle per Section 14 (Fuel tank
– removal).
(16) Remove the fuel pump module from the fuel tank per
Section 14 (Fuel pump module – removal).
(17) Install new Performance Fuel Pump Module per Section
14 (Fuel pump module – installation).
(18) Install fuel tank into vehicle per Section 14 (Fuel tank –
installation).
(19) Replace MAP and TIP Sensors per the following
instructions (Skip for kit P4510339).
K68587011 10/01/04 Page 2 of 6
MAP SENSOR
REMOVAL
A. Locate MAP Sensor on front of intake manifold.
Fig. 6 Map Sensor Location
B. Disconnect electrical connector at MAP Sensor (Fig.
6).To remove connector, unlock connector by pushing
red tab toward the wire harness, and then
depress the center lock and pull the connector from
the sensor.
C. Remove two screws attaching MAP Sensor to intake
manifold.
D. Withdraw MAP Sensor from intake manifold.
MAP SENSOR
INSTALLATION
E. Apply a light coating of clean engine oil to MAP
Sensor O-Ring.
F. Install new MAP Sensor supplied into intake
manifold.
G. Install two fasteners retaining MAP Sensor to intake
manifold.
H. Torque fasteners to 35 in/lbs.
I. Attach electrical connector to MAP Sensor, push
lock tab into lock connector.
TIP SENSOR
REMOVAL
J. Locate TIP Sensor on left-hand inside fender (Fig. 7).
K. Disconnect electrical connector at TIP Sensor (Fig.
7). To remove connector, unlock the connector by
pushing the red tab toward the wire harness, and
then depress the center lock and pull the connector
from the sensor.
L. Remove the two clips attaching TIP Sensor bracket
to inner fender and save for reinstallation.
M. Remove vacuum hose from sensor.
N. Remove production sensor from bracket by gently
lifting retaining clip and sliding sensor off of bracket
flange. Bracket will be reused.
Fig. 7 TIP Sensor Location
TIP SENSOR
INSTALLATION
O. Locate new TIP Sensor supplied in kit .
P. Mount new TIP Sensor to original bracket by sliding
the retaining clip over the bracket flange until it locks
in place.
Q. Reinstall push clips through bracket and inner fender
mounting holes.
R. Push center of clip until flush with base.
S. Reconnect vacuum hose.
T. Reconnect electrical connector, push lock tab into
lock connector
K68587011 10/01/04 Page 3 of 6
(20) Review front cross member description in Section 13
(Front cross member removal). Mark position of front
cross member assembly in vehicle by tracing mounting
pads as shown in (Fig. 8).
Fig. 8 Mark Position of Front Cross Member Assembly
(21) Remove front cross member, steering rack and lower
steering shaft per Section 13
(22) Remove turbocharger assembly per Section 11
(Turbocharger – removal) and coolant and oil lines per
Section 11 (Lines and hoses – removal) and place aside.
(23) Install new Stage 3R Performance Turbocharger
Assembly in vehicle per Section 11 (Turbocharger –
Installation) and coolant and oil lines per Section 11
(Lines and hoses – installation). When torquing coolant
lines, be careful to note and maintain line orientation to
ensure proper fit. Slight trimming of the oil return hoses
may be required to ease oil return line installation.
NOTE: USE A SMALL AMOUNT OF ADHESIVE (E.G., CONTACT
CEMENT, WEATHER STRIP ADHESIVE, ETC.) TO ENSURE THE
2.5 MM THICK SHIM WASHER IS HELD IN PLACE UNDER THE
HEAT SHIELD DURING INSTALLATION OF THE MOUNTING
BOLT IN THE POSITION SHOWN IN (Fig. 9).
Fig. 9 Shim Washer Mounting Bolt Assembly
(24) Install front cross member, steering rack and lower
steering shaft per Section 13 (Front cross member –
installation).
(25) Replace engine oil filter and oil per Section 9 (Standard
procedure – engine and oil filter change).
(26) Reconnect the vacuum harness assembly per Section 11
(Solenoids and vacuum harness – installation).
(27) Perform vacuum hose securing procedure.
A. Inspect the entire vacuum harness to ensure that all
connections are securely connected and no damage
or breaks exist. Repair or replace any damaged
components before proceeding further with
installation.
B. Identify vacuum harness connections for the
following locations (Figures 10 & 11):
• Turbo Compressor Scroll
• Waste Gate
• Turbo Compressor Outlet
• Surge Valve
• Purge Solenoid Quick Connect
• Throttle Inlet Pressure (TIP) Sensor
• Clean Air Hose
• Throttle Body
• Intercooler Outlet Duct
C. Starting at each location listed in Step B, secure
each flexible rubber hose connection to the
appropriate vacuum line using the zip ties supplied.
Using diagonal cutters, trim excess material from zip
ties for a clean installation. Secure all flexible
connections in one vacuum circuit before continuing
to the next line location. DO NOT zip-tie the molded
connections directly on the vacuum solenoids.
K68587011 10/01/04 Page 4 of 6
K68587011 10/01/04 Page 5 of 6
Fig. 11
Fig. 10
NOTE: DO NOT INSTALL AIR CLEANER HOUSING AND INTAKE
HOSE IF TURBO TOYS KIT WILL BE INSTALLED AT THIS TIME.
FOR TURBO TOYS KIT INSTALLATION, REFER TO TURBO TOYS
KIT INSTALLATION SHEET INCLUDED WITH KIT.
(28) Replace air housing and intake hose installation per
Section 9 (Engine/air intake system/air cleaner housing –
removal).
(29) Perform final installation checks and starting procedure
below.
A. Install battery tray and connect battery per Section 8
(Electrical/battery system/battery – installation).
B. Remove Fuel Pump relay from Power Distribution
Center (PDC). For location of relay, refer to label on
underside of PDC cover.
C. Crank engine over for 15 seconds to build
oil pressure.
D. Turn ignition key to OFF position.
E. Check engine oil level check for leaks at
turbocharger oil line connections. Repair as
necessary.
F Return fuel pump relay to PDC.
G. One or more Diagnostic Trouble Codes (DTCs) may
have been stored in PCM memory due to fuel pump
relay removal. The DRB III scan tool must be used to
erase a DTC.
H. Turn ignition key to run position to pressurize fuel
system.
I. Turn ignition key to OFF position.
J. Check for fuel system leaks at fuel tank module, fuel
lines and fuel rail assembly. Repair as necessary.
K. Start engine.
L. Check for leaks at turbocharger coolant line
connections. Check for exhaust leaks or contact with
adjacent components. Repair as necessary.
M. Drive vehicle for 100 miles at minimal engagement of
boost. Check all fasteners and connections to ensure
that all are at specified torque values.
K68587011 10/01/04 Page 6 of 6
Old Jan 16, 2005 | 05:13 PM
PSI Chick's Avatar
PSI Chick
Default RE: Stage 3 Information sheet
if anyone needs more claification on this, the pdf version has some diagrams in it that couldn't be coverted to this format. i am going to see if i can maybe host just this pics....
thanks caspter!
