Go in the boost menu and set the target to whatever you want. Since the Detec isn't smart enough to hit the target boost that you set it at, you have to go in the boost options menu and change the duty percent so it holds at the boost that u want.
The Detec knows what gear you're in. When u go in the boost menu, it even shows what gear you're in while driving. The arrow is next to that gear.
Go in the edit maps area, then the boost menu, then select the gear that you want to mess with. Then do what I stated above.
