Just installed AGP wastegate and have a ?
Old Dec 4, 2008 | 02:34 PM
03blacksrt4's Avatar
03blacksrt4
if you are refering to my post no i am not joking. i did it because i was gonna put a boostcontroller but i didnt pass the 11 pounds. i think i must have a leak
Old Dec 4, 2008 | 05:41 PM
mxrnick's Avatar
mxrnick
so u took the hose off the wastegate and drove it round? or disconected the rod?
Old Dec 4, 2008 | 08:03 PM
03blacksrt4
yes i took the hose off the wastegate and nothing. one minute earlier i did it to my friends srt and tHAT thing went to 20 pounds in a heartbeat, but mine nothing did not pass the 11psi. i just replace my waste gate with my friends stock one that doesnt hold more than 14 psi but a leats goes to 18 and then drops to around 14-15 psi and nothing happend i still seen the 11 pounds.
Old Dec 5, 2008 | 09:41 AM
PSI Chick's Avatar
PSI Chick
first off....don't EVER EVER EVER do that again. it's ****ing stupid. unless of course you're trying to blow up your motor and turbo, then by all means have fun with it. try pnp'ing your head by sticking your intake into a bag of sand too while you're at it, they're both great ideas.
disconnecting the wga and stomping on it isn't a way to diagnose anything at all. so put everything back together and work from there. you probably have a bad wga or it just needs to be adjusted.
Old Dec 5, 2008 | 10:58 AM
03blacksrt4
PSICHICK, first of all i know what can happend to an engine if it goes lean. i never said i step on the car all the way the moment i saw my friends car pass the 17 psi i let go. of course i already tried changing the wg i used my friends stock one does not hold the pounds but at leats goes pass 17 psi i put it on my car but nothing. im guessing i have a leak somewhere.ohh and that thing with the bag of sand you told me to do i already try it in my 700awhp dodge stealth and nothing happend to it just kidding
Old Dec 5, 2008 | 11:33 PM
STILL GH3TtO's Avatar
STILL GH3TtO
dont get crazy wit her, what you did to your car is not a smart idea, No one one here cares about what you say you have or whateva, put you car back together and do a boost leak check. (which I am sure you know how to do since you have a 700 hp awd stealth) See where that takes you...... On and next time your sucking sand with your intake, make sure you dont get any in your panties. It makes you cranky.
Old Dec 6, 2008 | 09:16 AM
03blacksrt4
hey wtf is your problem i just replied to her post in a nice way. i was just asking a simple question and something i did to my car and you all got all crazy because i just disconnected my wastegate. and STILL GH3TTO mind your own bussiness
Old Dec 6, 2008 | 03:45 PM
STILL GH3TtO
This is a public forum, so its everyones business. Do the boost leak check, and let us know
Old Dec 6, 2008 | 05:51 PM
03blacksrt4
STILLGH3TTO i really appreciate your concern about my car's health thank you. i will let you know when i do the check.
