PULLING CODE P1188??? HOW DO I FIX IT??
Old Jun 20, 2008 | 02:49 PM
SRT454SS's Avatar
SRT454SS
Member
Default PULLING CODE P1188??? HOW DO I FIX IT??
My check engine light went off and i thought it was a PCV but it pulled a code P1188..i dont really know my way around these engines too well yet. How can i fix this because i was supposed to get a sticker by today..any help would be very appreciated as i need this car for work. If i need to replace parts how much do i have to spend if any..i have a cold air intake, downpipe,cat,borla,and stage 2 kit however only the wastegate is on the car right now so i can get a sticker. Is this something thatcame with the stage 2 kit that i can swap out????
Old Jun 20, 2008 | 04:34 PM
PSI Chick's Avatar
PSI Chick
Default RE: PULLING CODE P1188??? HOW DO I FIX IT??
that's an overboost code. how much are you boosting? under 20psi or so shouldn't be throwing that on s2. turn your boost down and reset the ecu.
Old Jun 20, 2008 | 06:11 PM
Moparmatt440's Avatar
Moparmatt440
1188 isnt a over boost code it TIP sensor performance, TIP (throttle inlet pressure), when you install the rest of your s2 kit you will be repplacing this sensor, its located on the driverside insdie fender, you white tube from your solinoid goes to it. Just disconnect your neg. battery cable for about 20 seconds and it will reset the ecu.
Old Jun 20, 2008 | 07:37 PM
PSI Chick's Avatar
PSI Chick
it's "AN" overboost not the overboost code. it's a very common code to throw.
Old Jun 21, 2008 | 10:28 AM
NeonDon's Avatar
NeonDon
Tastes great, less filling, tastes great, less filling
Old Jun 21, 2008 | 10:29 AM
SRT454SS's Avatar
SRT454SS
Member
riddle me this, i have the TIP sensor still there from the stage 2 but not hooked up. could i just plug in the stage 2 TIP sensor? and im only peaking like maybe 18-19lbs and with teh stage 2 wastegate holding like 15lbs. if i reset my computer like you said, could i pass inspection???
Old Jun 22, 2008 | 04:47 AM
AWH's Avatar
AWH
You can try that, and after driving it 50-100 miles the CEL stays off, then it should pass. Don't try to just reset it right before going to inspection. If the car hasn't been driven 50-100 miles, you will fail for "not ready" status. At least that's the way it is in NJ. I agree, try lowering the boost. Maybe put the stock WG back on if need be.
Old Jun 22, 2008 | 11:01 AM
SRT454SS's Avatar
SRT454SS
Member
do you think that would work?? i know mass and NJ are very similar if not identical in their inspection requirements
Old Jun 22, 2008 | 03:07 PM
PSI Chick's Avatar
PSI Chick
so you're tip sensor isn't hooked up? [:@]wow.....
hook up the sensor lol
Old Jun 23, 2008 | 06:02 AM
AWH's Avatar
AWH
Yeah if you don't have the TIP sensor hooked up, hook it up. Better yet throw the stock TIP sensor back in just for inspection. Make it as stock as possible.
I don't know how you went about pulling up the code but you can also check it by turning the key ON-OFF-ON-OFF-ON and it will display the code(s) on the odometer, and display "dOnE" when finished. If it just says "done" then there are no codes being thrown and it is ready to inspect. I forget exactly what happens if it is not ready, but I think it will just display dashes across the screen. I will check on that and let you know. If it is "not ready" it will not pass inspection.
