Drag Radials
Old Jun 27, 2008 | 11:00 AM
PSI Chick's Avatar
PSI Chick
Default RE: Drag Radials
a steelie isn't a good rim lol....and there are no 7" steelies, they're al 6.5". get a decent pair of rims so they don't weigh 45lbs each, as that slows you down. there are lots of cheap rims out there, just watch the weight.
Old Jun 27, 2008 | 03:47 PM
Kapitald's Avatar
Kapitald
okay awesome thanks for all the help....got it...cheap lightweight 7" rims...
Old Jun 27, 2008 | 04:17 PM
STILL GH3TtO's Avatar
STILL GH3TtO
how well do slicks actually grab? How high can you hold you rpms while your at the tree and have the tires grab well at launch? How long should you do the burn out for to get the itres good and sticky? what tire pressure should slicks be at for best traction?
Old Jun 27, 2008 | 04:27 PM
PSI Chick's Avatar
PSI Chick
slicks grab extremly well. most of the time you can cut about .5s off your times with them.
you need to launch from a high rpm with slicks. i launch from about 5k.
the burnout on slicks isn't as picky as with dr's. you can burn the hell out of them, or just do a small one, they'll be ok. i usually go until i see smoke over the hood, then let her out of it.
tire pressure is going to vary on slick size and the car. i run my slicks as 12.5psi cold, and will drop them back to that after each pass.
Old Jun 28, 2008 | 12:05 AM
Kapitald's Avatar
Kapitald
wow 12.5 psi really....that seems low...but i dont know what the max on a slick is either....i was running 20psi on my street tires...maybe coulda went to 16-18 for a lil better grab...
Old Jun 28, 2008 | 01:25 PM
PSI Chick's Avatar
PSI Chick
12.5 is low? ha i ran 8psi in when i had my hoosiers! these are wrinkle wall slicks, they need a lower psi to get them to work properly lol
Old Jun 29, 2008 | 02:11 AM
Pressurecooker's Avatar
Pressurecooker
Yeah uh... 16 is probably too low for a street tire. Depending on profile and make etc. At about that pressure, I was spinning my tires on the rims. Not good! Plus, you will start to "cup" the tread which reduces the tire contact which is also not good. I would stay around 20 or more.
Also, you need not just cheap + light rims. You need cheap, light + strong rims.
Old Jun 29, 2008 | 12:39 PM
PSI Chick's Avatar
PSI Chick
most of the light wheels are strong, it's actually the heavier ones that are usually crap. to make them light they have to use better materials and processes.
