Srt hit the 50,000 mile mark....
Old Jul 1, 2008 | 09:57 AM
PSI Chick's Avatar
PSI Chick
Default RE: Srt hit the 50,000 mile mark....
200? haha yea in parts. try more like 400-500. timing belts on our cars are a bitch.
Old Jul 1, 2008 | 03:56 PM
Plan B's Avatar
Plan B
Definately change the tranny fluid. Maybe brake fluid too. At least bleed them.
As for timing belt @ 60k.... Really? I thought it wasn't suggested until about 90k? Out of the whole 'crew', we've only done one so far at 80k+. About to do mine @ 85k, but I might be replacing a head gasket so that is why I'm thinking of doing it before the 90k mark.
Might not be a bad idea to check all the suspension bushings, endlinks, etc.
I had to replace my tstat, might want to check that as well... Definately do the normal accessorybelt. Very easy to do.
Old Jul 2, 2008 | 12:44 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
^i cant believe i have neglected it, but i havent yet bled the brakes in the SRT. then again, im at 36k on the original rotors, so im not doing much hard braking.
Old Jul 2, 2008 | 10:52 AM
lblackneon's Avatar
lblackneon
If I remember correctly, I bought the whole panel for the tensioner and that ran $120 by itself.
Old Jul 4, 2008 | 10:24 AM
AWH's Avatar
AWH
I have 100K+ on my 03 and I just did the timing belt, water pump, and tensioner at around 95K. Never had problems. Just to be safe, I would reccommend changing them at around 85K, so start saving now lol. You should also change the air filter. Otherwise, look in the service manual and see what they suggest at 60K since you are within 10K miles.
Old Jul 6, 2008 | 12:35 AM
Pressurecooker's Avatar
Pressurecooker
Changed the left outer tie rod last weekend, only to find out the right is pretty worn too. I'll be doing that next weekend. Hmmmm.
For what its worth, I think the replacment TRW rod end I got is a much better piece than the oem unit.
Old Jul 6, 2008 | 12:47 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
I would have been 70 years old before I had to do most of this stuff to my SRT-4!!!! And yes, I still miss it. Today I started my truck and my left foot went right to the spot where the clutch pedal would have been on the SRT-4........and I still reach for "air" where the shifter would have been..........
Dusty
Old Jul 6, 2008 | 12:51 AM
VTSRT4's Avatar
VTSRT4
I'll have to look out for these types of things 42,000 miles down the road.
Dusty, how come you gave up thisbeautiful piece of machinery(except for the *** end)?
Old Jul 6, 2008 | 11:09 AM
PSI Chick's Avatar
PSI Chick
remember too it's not just mileage but also age. belts and other rubber parts start to dry out and crack, so you need to check your parts and make sure they don't need replacing. justbecause a car only has say 40k on her, but is 5 years old, doesn't mean that belts don't need to be changed. it's kinda like an oil change, mileage OR time, both play a part in maintenence.
also, if your doing any major work to the car that requires removing of the head it's a good time to change everything anyway, just as a preventative measure.i'm also not a fan of putting used belts back on a car. they're cheap, just get a new one.
Old Jul 6, 2008 | 02:34 PM
lblackneon's Avatar
lblackneon
I've actually heard that you don't have to replace the timing belt until it breaks. I heard that on these cars, it doesn't break anything. I wont try it though.
