Need Some Advice?
Old Jun 28, 2008 | 06:01 PM
pepaint's Avatar
pepaint
Default Need Some Advice?
Today I installed a set of Tokico shocks and the Eibach front and rear sway bar kit. Took about 4 hours. Now this is whereI need some advice.I was also thinking of getting the Mopar rear tension strut kit and Energy Suspension bushing kit. With the Eibach front and rear sway bar kit it did come withall new bushings, so would the Energy Suspension kit be worth it? Let me know what you think. Thanks
Old Jun 28, 2008 | 07:23 PM
PSI Chick's Avatar
PSI Chick
Default RE: Need Some Advice?
nope not worth getting the kit. if anything just get a set of lower control arm bushings and you should be good to go.
Old Jun 28, 2008 | 08:15 PM
LilSparkPlug's Avatar
LilSparkPlug
Just go to EnergySuspensionParts.com and buy the pieces that you need (in either black or red). The kit will come with front and rear endlinks (which you have), front and rear swaybar bushings (you have these too), tension strut bushings (mopar upgrade will include these), shifter bushings, and front lower control arm bushings. That website is the cheapest I have found these kits anywhere.
Old Jun 28, 2008 | 08:29 PM
pepaint's Avatar
pepaint
Thank You Ladies, I appreciate the info.
Old Jun 29, 2008 | 12:43 PM
PSI Chick's Avatar
PSI Chick
why would he buy a kit that contains 5 pieces, 3 of which he already has? that's just stupid lol. just get some lower control arm bushings and you're good to go. if you really want the shifter bushings get some boogers, they're $20.
Old Jun 30, 2008 | 09:21 PM
pepaint's Avatar
pepaint
how hard is it to install the front control arm bushings?
Old Jun 30, 2008 | 10:00 PM
LilSparkPlug
ORIGINAL: PSI Chick
[/align][/align]Before you post a comment I suggest you read my entire post. The FIRST sentence in the post states: [/align][/align]
[/align][/align]I then told him what the kit comes with in case he wasn't already aware. I never told him to buy an entire kit. But that website is cheaper than any other ES dealer even for just pieces. [/align][/align]Lower Control arm bushings are installed easiest with a hydraulic press. Some people burn them out but I don't recommend it, its kind of hack. Once you install the kit you'll need an alignment, so be sure to set that up afterwards. The factory service manual states that you should remove the entire control arm to install these, and its right. They're a PIA to put in, but not impossible.[/align][/align] [/align]
Old Jul 1, 2008 | 04:07 PM
pepaint's Avatar
pepaint
No need to fight ladies, there is plenty of me to go around (J/K).Seriously though,I do have access to a shop press and a torch (if all else fails). Another quick question, is there a manual or website to find the torque specs for our cars?
Old Jul 3, 2008 | 01:28 AM
Kapitald's Avatar
Kapitald
meow psst psst lol
