panle acting up
Old Jul 1, 2008 | 09:33 PM
theguyfromtx's Avatar
theguyfromtx
Default panle acting up
So I had just left bestbuy and got in the car and was trying to start it and it was a no go. After hours of messing with it me and a couple people noticed the starter wire was bad so we took care of that and I jumped in started her up and then came to realize the insturement panle was reading "no bus" and none of my guages worked minus boost and gas!! Does anyone have any pointers for me?[:@][:@][X(][X(]
Old Jul 2, 2008 | 12:46 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: panle acting up
wow, guess start off by checking all of your wiring harness connections. something is amiss there for sure[&:]
so the car starts and runs or not? just the instrument panel is jacked up? tried resetting the computer?
Old Jul 2, 2008 | 02:37 AM
theguyfromtx
Yea got the car to run, just the panel is not working now......mmmmmmmm not really sure how to reset the comp in this car.[&:]
Old Jul 2, 2008 | 09:02 AM
flamingpinhead
Section Moderator
well, you can try resetting the pcm by disconnecting the battery, leaving it off for a few than then reconnecting it. but a wiring harness comming disconnected would cause your panel to lose signal, thus have no readings. (boost gauge would work as its separate... same with fuel). could check the speed sensor on the side of the tranny, but it sounds like an electronic issue. and i have heard that 'no bus' before. i have to leave thismorning, but ill try to research that later, as i know its come up before.
Old Jul 2, 2008 | 10:14 AM
flamingpinhead
Section Moderator
https://dodgeforum.com/m_740167/tm.htm
its a communication issue between your ecu and cluster. try resetting the ecu. if that does not work, again, make sure all your connections are good between the ecu and cluster, its possible something came loose?
Old Jul 2, 2008 | 05:19 PM
theguyfromtx
Hey thanks for all your help, ill go check it out before I run it to the dodge dealership you already know there gunna stick it to me...[:@]
Old Jul 3, 2008 | 01:21 PM
flamingpinhead
Section Moderator
...unless your still under warranty
