Stage 1 info
Old Jun 29, 2008 | 09:49 PM
SRT48U's Avatar
SRT48U
Default Stage 1 info
So i installed a stage one kit a while ago in SRT and i was just wondering the benefits of it.
Some guys say that it eliminates a exhaust code so you dont need to install a catalytic
and you wont get a check engine light if you want to run a 3" turbo back???
Any info on the stage 1 kit would be great thanks
Old Jun 30, 2008 | 01:31 PM
Plan B's Avatar
Plan B
Default RE: Stage 1 info
S1 will allow you to run a catless downpipe and will also let you run higher boost w/o throwing a code. Pretty much a less pickier version of the stock ECU
