sub holders. ??
Old Jul 6, 2008 | 04:54 AM
neondriver134's Avatar
neondriver134
Default sub holders. ??
Hey i was wondering if anyone knew where to get kicker subs and enclosures that come stock with some SRT 4s mounted on the side. im thinkin about puttin 2 in my neon. let me know. thanks
Old Jul 6, 2008 | 01:08 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: sub holders. ??
mounts on the side like so:
its held in place with one of the tail light nuts, a bolt at the top, and velcro-like stuff that sticks it to the carpet at the bottom.
Old Jul 7, 2008 | 09:20 AM
AWH's Avatar
AWH
You can probably only get those through a dealership, but I'm not sure. Also, what size sub mounts in there?
Old Jul 7, 2008 | 06:30 PM
dparsons06's Avatar
dparsons06
I have one i will sell
Old Jul 8, 2008 | 08:33 AM
PSI Chick's Avatar
PSI Chick
if you want subs just go and get a real box. those dinky little things don't do a whole lot.
Old Jul 8, 2008 | 12:41 PM
flamingpinhead
Section Moderator
ORIGINAL: PSI Chick
yes, very true. they add depth to your sound, but if you want to 'thump' youll be disappointing.
Old Jul 9, 2008 | 07:47 AM
AWH's Avatar
AWH
^ True, if you want a "tight" bass sound, they are probably okay, but for maximum boom, thump, and efficiency, nothing beats a bandpass box.
Right now I have a bandpass with 2 Kicker 10s in it running off a 600 Watt amp in the trunk (which I can easily remove when I need the trunk space) plus a 200 watt infinity bass link (inside the car). Ridiculously loud.
Old Jul 9, 2008 | 09:54 AM
PSI Chick's Avatar
PSI Chick
kicker's...eh. if you want real music get some JL Audio stuff. now that's bass.
Old Jul 11, 2008 | 07:08 AM
AWH's Avatar
AWH
ORIGINAL: PSI Chick
That depends on which JLs you are talking about. The Kicker's I have are from 1996, made in USA,and cost $300 apiece back then. I would put them up against most JLs any day. I would only consider the W6 and W7 series from JL to be better than these. Also the box plays a huge role in theamount of bass, sound character,and efficency of your setup.
Old Jul 11, 2008 | 01:03 PM
flamingpinhead
Section Moderator
hell, lets start with the head unit. a cheap-o head unit is gonna make ANY sub / box / amp combo sound crappy in comparison.
as AWH said, there are many many variables in a system's setup
