i got a few questions
Old Jul 10, 2008 | 11:39 PM
drewthatsmenb's Avatar
drewthatsmenb
Default i got a few questions
alright heres the run down i have a few questions about my 50 trim set up 1 what kind of plugs would you guys recommend and what should they be gapped at and 2 i just bought the stage 1 pcm would it be smart to take out my s-afc when i install it and run off of just the pcm or should i leave it in when i put in the pcm? would it screw around with the pcm and posibly lose power and or throw codesif i try to tune the car via s-afc?
Old Jul 11, 2008 | 01:30 PM
2006DAKOTAV8's Avatar
2006DAKOTAV8
Default RE: i got a few questions
NGK plugs...gapping i'm not to sure but stock setting should be substantial! but like i said i'm not positive for that set up! but running the S-AFC should be fine with the stage 1 computer buddy has it and also has Stage two it'll be fine to run with the computer! no you wouldn't loose power you would be able to tune and monitor your car from your drivers seat! ****s actually pretty sick man!
