sage 1
Old Jul 16, 2008 | 11:11 AM
jnmopar71's Avatar
jnmopar71
Default sage 1
what is the max boost i could run if i get stage 1? I have mopar bov, agp wtg, k&n cai, occ, msd wires, and down pipe.
Old Jul 16, 2008 | 01:24 PM
PSI Chick's Avatar
PSI Chick
Default RE: sage 1
15-16psi. the issue is fuel.
Old Jul 16, 2008 | 05:15 PM
jnmopar71's Avatar
jnmopar71
Default RE: sage 1
even if i up the boost ?
Old Jul 17, 2008 | 09:10 AM
PSI Chick's Avatar
PSI Chick
Default RE: sage 1
if you up the boost you have even more of a problem with fuel, or i should say a lack of fuel.
Old Jul 17, 2008 | 01:21 PM
jnmopar71's Avatar
jnmopar71
Default RE: sage 1
so what would i need? And would it be an easy fix? sorry i bet you've told this to a lot of people.
Old Jul 17, 2008 | 03:55 PM
STILL GH3TtO's Avatar
STILL GH3TtO
Default RE: sage 1
see the problem is that the stock fuel system is not made to run over 16 psi, If you wanted to run more boost you have to upgrade your fuel. A new fuel pump and injectors would be a good start, then a fuel return kit if you plan on going big
