boosting 15psi but sluggish
i have a kinetic wga and have it set at 15 psi but when i step down on it. Its reading 15psi but fells sluggish other mods are map clamp but not tuned tip mod 3' exhaust bov and hard pipe do i have a boost leak im going to do a boost leak test any help would help. Mopi
if you had a leak, i think you would be losing pressure and not still be at 15 psi (which is normal).
have you lost power suddenly or has it been a slow progression to slow over time?
i would look towards your spark. how old are your plugs / wires? losing a good spark will make it feel sluggish compared to how it used to.
https://dodgeforum.com/m_1360632/tm.htm
Granatelli is what im going with.
plugs only have 1000 miles on them they should be good (assuming there were no issues with them when you put them in).
how many miles do you have on your car? probably your wires do need replaced.
