Dog Bone Engine Mount Smashed Oil Pan
Old Aug 7, 2008 | 03:08 PM
srt-4-red's Avatar
srt-4-red
Default Dog Bone Engine Mount Smashed Oil Pan
Saturday at the drag strip my new dog bone motor mount left a whopping hole in my oil pan on the first run of the day. $700 damage. How do I prevent this from happening again?
Old Aug 8, 2008 | 07:56 AM
PSI Chick's Avatar
PSI Chick
use locktite on the bolt
Old Aug 11, 2008 | 11:40 PM
srt-4-red's Avatar
srt-4-red
As it turns out the dog bone nut & bolt were right tight.
I put two sheaths of copper tubing around the bolt in the mount (at the oil pan end)to give it less play this time. Any other ideas?
Is the mount slamming up into the pan, or is the whole engine slamming down onto the mount?
Old Aug 12, 2008 | 01:09 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
could be the whole thing moving. check your other mount perhaps///
Old Sep 21, 2008 | 12:41 PM
srt421's Avatar
srt421
i had my top dog bone motor mount totally seperate from the little bushing inside it, could it be fixed or should i try to send it back to agp?
Old Sep 21, 2008 | 12:51 PM
srt421's Avatar
srt421
Old Sep 21, 2008 | 04:35 PM
STILL GH3TtO's Avatar
STILL GH3TtO
I have an oil pan I will sell ya?
Old Sep 22, 2008 | 04:46 PM
srt-4-red's Avatar
srt-4-red
Thank you flamingpinhead. You were right, the top engine mount had loosened a bit.
I tightened it and added an extra support bar from the fender wall to the lower mount. I don't know if that was a dumb idea or not, but the track is 200 clicks from my house and I can't afford another tow.
Anyhow, it didn't give me any grief on this Friday's excursion to the track, though I was easy on the starts so as no to get too much wheel hop.
Any suggestions on how to eliminate wheel hop? I have 235/17s with the best new Pirelli p-zero rubber I could find.
Old Sep 25, 2008 | 01:07 PM
LilSparkPlug's Avatar
LilSparkPlug
There are companies that sell traction bars, H-braces, etc. to try and keep the front wheels planted. Check out BWoodyPerformance.com they are one of the companies that sells these parts. As for the bushing, AGP sells dogbone bushings, washers and bolts separately.
