need fuel help
Old Aug 16, 2008 | 06:08 PM
PSI Chick's Avatar
PSI Chick
the afc neo is ok, but is certainly not a standalone and i believe still has the limitation of whole percentage points being pulled. unfortunetly the dtec is no longer made, that was so much better.
again, you CAN NOT add fuel with the neo. yes it says that you can, but the car won't do it. stop trying.
besides on a stock turbo with s2 injectors the last thing in the world you should need is more fuel. you should be pulling like 15% lol.
Old Aug 16, 2008 | 09:17 PM
1fast04neon's Avatar
1fast04neon
yea i know i have a 20g but i still should be pulling
Old Aug 17, 2008 | 09:08 AM
PSI Chick's Avatar
PSI Chick
oh i didn't know you had a 20g. that's still plenty of fuel though for that turbo. it's probably the pump. replace it and zero out the afc and see where you're at.
Old Aug 17, 2008 | 07:24 PM
1fast04neon
yea im gonna when i get back... im in oc right now but i ordered a new pump and a 10g wire with a relay to rewire hopefully thats it car wont even start right now
Old Aug 23, 2008 | 10:02 PM
1fast04neon
ok so i ditched the coil because it died on me 20min from my house car starts up i rewire the fuel pump and move my fpr from a vacuum source to a boost only source car runs horrible the tune is all messed up..... b/c of fpr location???? it was tuned to the vacuum/boost any suggestions
Old Aug 25, 2008 | 04:02 PM
PSI Chick's Avatar
PSI Chick
the tune is going to be messed up because you went from a rising rate to a steady rate pressure. what's your pressure at and what kind of a/f's are you seeing?
Old Aug 25, 2008 | 11:08 PM
1fast04neon
well i put it back for now until i get back to the dyno... i am at down to 47ish at idle now.... afrs like 11.3 probably lil rich with meth but better safe than sorry right now... some spots hitting 10's but still cant get anymore than 16lbs....??????
